E machine reboots - Computers & Internet
  • 1 more comment
  • Andrew Feb 09, 2008
    Unfortunately XP will not even load, it gets to the e machine screen and reboots. It will not boot to safe mode or last known good configuration.
  • granny_63650 Jan 23, 2009
    my comp was running just fine,then one day bam!,it starts,windows goes to loading then it reboots by itself......everytime....grrrrrrrrrrrrrrrrrrrrrrr
  • Hairy29 May 11, 2010
    hi!good am...
    can you be more specific sir?
    thanx...
    Problem Solver:
  • 42 Answers
Hi!good am...hope this will helip...
i had this problem before and i reformat my hard disk and install a new operating system.i tried to repair my system but i couldn't find the file corrupted...maybe your system has a problem as i was before and i think its a software (operating system) issue...i hope you have back-up on your files.
Posted on Feb 10, 2008
  • 537 Answers
Which operating system are you running? If WinXP, check the following:
From the run menu.type "sysdm.cpl" (no quotes)
Then click the 'advanced' tab.then start up and recovery settings.
Make sure the item marked 'system failure: automatically restart' is NOT checked. Then click OK, then restart your system to enact the changes. If your computer BSODs, you will see the STOP error.
Mike
Posted on Feb 09, 2008
  • Mike McWhinney Feb 09, 2008
    if you can monitor your CPU temperature, do so. Does your BIOS/CMOS setup have this? A CPU that is very hot is unstable and will reboot. That is just one thought.
    Another thing you could do is test your memory with a utility like MEMTEST+ to see if that is the issue.
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
Tip
How to uninstall deep freeze
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you
can press Crtl-Alt-Shift-F6. You should now see a password dialog.
2. Enter your password and click OK. If you have not yet entered a password you should be
able to click OK without entering anything. You should now see a dialog with boot options.
3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze to this machine. By
default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for
versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
4. The software should uninstall and reboot the machine. When the machine reboots, Deep
Freeze should be uninstalled.
on Mar 15, 2010 | Computers & Internet
My copier machine Toshiba 7230 have error code CD10 when I'm copying. Sometimes The message "reboot machine" appear. How to solve the problem?
try pulling out the plug if that doesnt work try pulling the battery I believe by shutting it down you can reboot it. GoodLLuck to ya.
Dec 19, 2012 | Office Equipment & Supplies
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
I have an HP LaserJet 2420d all of sudden i have started getting the message: 49.4c18 service error. How do i correct it? Thanks, Alonso.
ok #1 run a scan on machine with your spammer and anti virus. if you get errors let the program correct and clean them. Then reboot, turn off antivirus program till completed.
ok costa try this for me remove your network cable let sit for about 5 min then plug back in reboot machine. when you connect go to hp's site down lastest version of the drivers. Then reboot machine. oh also turn your antivirus program back on after final reboot.
Sep 21, 2010 | Computers & Internet
Remove deep freeze from computer
To uninstall:
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 19, 2010 | Computers & Internet
I need to reboot my computer and when it starts up but i dont know how
How to reboot a PC.
  • Save work if it's in jeopardy. If your PC has frozen, attempt to save your data before rebooting your machine. Rebooting will almost certainly cause data loss. Attempt to save your data to your hard drive, diskette or portable media.
  • Step 2 Determine the steps your operating system has to go through to reboot. Some operating systems allow you to press Control, Alt and Delete to reboot the PC. Others require different commands. However, if the operating system and software are frozen, you may use the power button on the machine or the power strip.
  • Step 3 Use the power switch if necessary. If you cannot access the shutdown feature of the operating system and the relevant buttons still won't allow for a reboot, press and hold the power button on the PC. Allow the machine to rest for a few seconds, then power back on.
  • Step 4 Wait for the power-on self-test. Allow the PC to check its components thoroughly through the initial boot screens that will appear.
  • Step 5 Resume working. Log back into the machine and continue to work.
  • Jun 23, 2010 | eMachines EL1310-01 Desktop PC
    Machine reboots when it is hot docked
    This sounds like a common feature of the T60, when docked it requires a reboot also try to reboot 2-3 time a day to help cooldown. IBM is a quality machine, even go as far as buying cooling extention for the T60.
    Apr 29, 2010 | IBM (250410U) Docking Station for ThinkPad
    Samihullah
    To uninstall:
    Mar 15, 2010 | Sony VAIO PCV-W600G PC Desktop
    CanonIR 5570 Copier reboots then jams at sorter
    Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
    Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
    Check sorter indicator lights (if any) after reboot,
    Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
    Jan 12, 2008 | Office Equipment & Supplies
    Computers & Internet Logo
    77 people viewed this question
    Alun Cox
    David Payne
    David Payne
