Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer won't copy
Printer says ,print cartridges are missing or not detected. printer is only 1 month old. I have unplugged it, took cartridges out, and still stays the same, can you please help.
  • 983 Answers
If you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time.
any way if problem persists you will be having warranty just contact the service person....
Posted on Feb 09, 2008
MY HP printer can print but does not copy
Same thing just happened to my fairly new 7520 Hp.
I shut my machine first with the shut off button and then unplugged
it for about 5 minutes. Sounds like you tried this and I believe this did not work for me either so I just went into the HP official site and downloaded my printer again. Downloading your printer from their
site is easy and quick instead using the cd. It automatically removed my old printer and installed the printer again. The problem has not returned.
Another problem I just had and because I think one of my new
cartridges (yellow) is somehow damaged. I got a black line down
my pages with a note that my yellow ink is missing. Had black line only when printing and not copying. I reinserted the yellow ink and took a light damp qtip and slightly wiped the machine screen on each ink cartridge.(this screen meets the new opening from each
new cartridge. The black line left.
Hope this helps.
Jan 02, 2015 | HP PhotoSmart Office Equipment & Supplies
HP Photosmart displays a message saying "Printer Cartridge(s) missing or not detected" though I've just put a new cartridge into the machine. How do I fix this so I can print again?
Remove the cartridge.
Make sure that you removed a piece of clear plastic tape that covers the ink-jets. It's placed there to prevent the ink from drying-out while the cartridge has been sitting on the shelf at the computer store.
Re-insert the cartridge, and be sure that it "clicks" into place.
Apr 02, 2010 | HP Photosmart C4280 Aio Printer
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
'Print cartridge missing or not detected' Message
You better buy a new printer.Probably you have a problem in carriage unit on your printer.
Oct 05, 2009 | HP Photosmart C4280 Aio Printer
D5360 Printer Flashes "Print cartidge(s) missing/not detected."
These Steps should get you pointed in the right direction....
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458297&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Copy and paste in your browser ...
May 21, 2009 | HP Hewlett-Packard D5360 Photosmart Inkjet...
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Dell Printer 926 cartridge error
I had the same prob..... I fixed it I took a clean soft rag sprayed Windex on it wiped off the ic type board on the front of the cartridge and also the board on the inside that the cartridge rest up against,,, turned it off and on put a copy under the scanner and kaabam it printed a month of pulling my hair out it works
Aug 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
May 21, 2007 | Lexmark Optra S 2450 Laser Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
550 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
