Question about Graco Apsen 3-in-1 8740 Crib
Broken bed spindel
My 22 month old grandson pushed against one of the bed spindels and it broke.....what should we do?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 109 Answers
Most if not all of the simplicity brand drop-side cribs have been recalled, including the Graco 8740.
Here is the CPSP link regarding this crib:
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml09/09260list.html
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
According to the CPSP information the company appears to be out of business to some degree and are not providing repair kits.
If you know where you purchased the crib, check to see what their policy is regarding recalled baby products.
We had purchased ours at walmart almost 8 years ago and were able to return it to another store in a different state for a full refund last summer. They did not need a receipt received, they just needed the manufacturer label on the part that the mattress lies on.
Because ours was older, the customer service clerk did have to work hard to find the crib in their system, but once she did, it was not problem at all.
Because it's been recalled, the break will not likely affect your ability to return it.
Posted on Jan 04, 2010
Toro timecutter 5060 runs when cold then cuts off after using a while
you may have spindel bearing going bad run the mower till it stops check the spindels for heat bet one of them is locking up if you find one remove it take it apart and take them to auto parts store and match them up it wil save a lot of money or buy the whole spindel hope this helps.
Sep 24, 2017 | Toro Garden
Have a mtd ranch king model #136Q699H205 that quits running after 20 minutes
if you are moweing at the time it is probably one or more spindel bearings is sezing next time it does it feel each spindel for excess heat if one has you found the trouble replace entire spindel or take it apart and take bearings to your local auto parts store it saves money
Sep 04, 2013 | Mtd Garden
HAVE A TROYBILT RIDER AND IT KEEPS BREAKING THE EXTENSION SPRING. WHY
check your spindel bearings for being bad or idler pulley on top of deck
Jul 09, 2013 | Garden
I have a 84 f250 and I need to change the u joint I have the hub apart down to the spindel, I took the nuts of the studs and couldn't get it, so I took the studs out and still can not get it to come...
If you have everything off including the axle nuts you can dry a air hammer with a flat head against the flat surface of it or you might have to use a puller.
Jan 09, 2012 | 1984 Ford F 250
How do you disconnect the rear wheel on a 1990 CBR 600
as in remove?if removal easyest way put on centre stand slacken chain adjuster nuts,then slacken wheel spindel,push wheel backwards so chain becomes real loose....undo wheel spindel fully tap wheel spindel out wheel should slide out
Apr 16, 2011 | 1990 Honda CBR 600 F(1)L
I bought a used stanley router and don't know how to take the old blade out. I like to change the blade.
There will be a button to push in which will lock the spindel. After locking the spindel you need to undo a nut using a wrench or spanner.
Apr 09, 2011 | Stanley Hand Tools
2002 1500 4 x 4 Replacing front wheel bearing hub; can't get to the 3 bolts
to start with, that is not a u-joint cover, it is a cv joint. if this is a chevy. you will have to pull the cv shaft out of the spindel. first loosen the outter tierod nut on the spindel, do not take off completely but just so its on finger tight. get a large hammer and hit the spindel right where the tierod goes through it. a couple of good shots and it should drop out take off nut and move outter tierod aside. now you are gonna do the same thing to the lower ball joint. only when your ready to hit that part of the spindel where the ball joint goes through get a prybar under the upper controll arm and get a budy to push up on it. as long as the shock is still bolted on your in no danger. pull the spindel out towards you from the bottom and you will have enough room to pull the shaft out of spindel to get the nuts. you might have to put ball joint back in without shaft in place to hold spindel still to break those bolts loose. make sure you use new cotter pins on ball joint and tierod nuts
May 30, 2009 | 2004 Dodge Ram 1500
1990 front wheel spindel
IF YOU GOT SPINDLE OFF THE CV JOINT MUST OFF. YOU HAVE TO HAVE IT PRESSED OUT AND IN.
Jan 04, 2009 | 1994 Ford Escort
Wheel studs
normally you can take off the spindel but if you remove brake disk and back plate you should be able to punch out the studs with no problem and than push new one in and press it in by tapping it with hammer on the back and than putting some washers over it and than tightening the lug nuts.
Or if you are comfortable with it remove the whole spindel section and put it on a work bench
Jul 21, 2008 | 1995 Ford Escort
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Baby Gear Logo
49 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
