Heating & Cooling Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My honeywell RTH230B won't do anything. I put fresh batteries in it, tried everything and nothing happens. What is the probelem and what can I do?
Frank Bryant Wetzel
Level 3:
  • Master 456 Answers
  • Posted on Jan 13, 2010
Frank Bryant Wetzel
Master
Level 3:
Answers
456
Questions
0
Helped
121768
Points
1116
If this is a typical air handler unit then turn the fan switch to on, if the fan does not come on then you have a control problem or no power to unit. Check fuses/Breaker.
If fuses and breaker are ok then try this. Turn the power off to unit, try and locate control board usually
located in the lower panel where the blower might be.
Disconnect thermostat wires that go to probably
r/w/g/y/c and remember what color goes to where.
If you can make a jumper wire or you have aligator
clips, jumper r and w. Put door back on, turn power on and heat should start up.
You can also put a jumper between r ang g terminals
instead and the fan should come on.
If either of the two cases happen, then you need another thermostat or check wiring to thermostat.
Another possibility is that there could be a car fuse
located in the control board that is blown
Good Luck
  • Frank Bryant Wetzel Jan 13, 2010
    Good Luck
1helpful
Honeywell RTH230B thermostat: everything works fine, but suddenly the Fan ON function doesn't work. The fan is OK (works on Auto in Heat mode), and I put in new batteries. What's up? John
To test if tstat is bad, remove the face plate. Turn power off and put red and green together and resume power. your blower should run. if it does the tstat is bad
4answers
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
2helpful
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
My Honeywell RTH230B temp control problems
Yes, some thermostats rely on batteries for power to run and maintain programming
2answers
Rth230b honeywell display screen faint
Mike, The static electrical spark probably 'zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps you. Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
1helpful
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Top Honeywell Heating & Cooling Experts
Paul Carew
john h
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
