Question about Fostex MR16HD/CD Digital Recorder
Display I am new at this. Never used this unit before. When I power up the Fostex the display illuminates but no menu or text is display. Is there something wrong with the unit, or is there a reset button or something.
    Brigadier General:
  • 6,966 Answers
Here is the link to your other post pls.
Posted on Feb 09, 2008
I refcently purchased a MR16 Fostex it comes on lights up and shuts down . What is possibly wrong ?
Power supply. Most likely an electrolytic is failing. It may or may not show any signs of it. Other possibilities are bad solder connections, loose wire connections, or possibly a bad MOSFET if it uses a switchmode power supply. Also check the general construction to make sure nothing is shorting internally. Sometimes wires get pinched.
Feb 14, 2012 | Fostex Mr16hd 16 Track Digital Recorder
Display error
1. Is it a stand alone or have you get it hooked up to a PC?
2. If with a PC, Win Xp or Vista, Mac?
3. Is the unit new, refurbished, bought from ebay or from a dealer.
If the unit is more than 2 years old then the only solution is to get it repaired or buy a new one instead.There are instances where internal software gets corrupted or even in some models, memory battery has leaked or depleted.
Unfortunately there is no external reset for the unit. It has to be opened up and diagnosed with the use of a special diagnostic PC and software. The firmware may also need to be re-installed or updated.
Am afraid your only best bet would be to open the unit and check the inside. Easy enough would be memory battery (if ever present) since they look like a thick coin (Lithium 3Volts) but other than that, most repairs would need knowledge and familiarity with electronic component and circuitry, a service manual, a DVM, a soldering iron and even as earlier stated some specialized equipment.
Perhaps your best bet would be to seek the services of a qualified professional or the nearest authorized Service Center.
Goodluck,
Please don't forget to rate the solution as fixya..
Apr 07, 2008 | Fostex MR16HD/CD Digital Recorder
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My Fostex MR-8HD recorder's LCD display won't show me anything when I turn on the recorder. Everything else power's on and works properly. I can even hear it it working. I can't see the LCD display...
Check if the display has a contrast control. When these get turned down, the display is blank. Sometimes they are a littel shaft coming out of the case, other times it is a setting in a menu... how they expect you to see the display to set it in these cases is beyond me...
Oct 22, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Hello. It's my first time on this forum. I just got a Fostex VF08 multitrack recorder from a friend of mine. But when I switch it on, the display is just orange, showing no text. All the commands seem to...
You will need to put th set on for really some time. I assume that the person who gave you must give more information if the recorder was working prior to this or was idling for along time.
If so leave the set on and allow the electronics to bring up voltage to all stages.
If there is no result look near the display unit the links, the cconnectors and the processor.
Now is your experienced friend can check out the prrocessor and display interface we can have some leads.
So check this out and respond
Sep 19, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
My screen fails to illuminate, I can make out text just barely but there's no light - I think it's the inverter? If so I found one to buy but I'm looking to at least see it in my laptop first, is it...
  • Hi, hope this will help you with your problem. There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Select, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. "Restart "Computer." *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Feb 02, 2010 | Toshiba Satellite L25-S119 Notebook
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
No display text
buy a new mobilephone..so easy...
Mar 30, 2008 | Motorola Mobility W220 Cellular Phone
Display error
Feb 09, 2008 | Fostex MR16HD/CD Digital Recorder
Display Problem
Feb 09, 2008 | Audio Players & Recorders
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
95 people viewed this question
Top Fostex Televison & Video Experts
Henry  Thomas
Henry Thomas
Michael Galve
Michael Galve
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
