Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Lint from the carpet not being picked up, why?
When i vacuum the living room, the lint from the carpet is not sucked up. It gets thrown back out and I have to pick it up by hand??
  • aida97 Feb 17, 2008
    It was a clog but I figured it out before I got your solution. Thanks anyways!! Its nice to know if I cant find out I know where to go!
    President:
  • 1,673 Answers
Either the brush roll is not turning, or you have a clog at the inlet by the brush roll or in the hose.
Posted on Feb 14, 2008
My vacuum has poor suction and I've checked the hoses and cleaned the filters. I don't know what's wrong.
I can't say this is your problem but many people assume their vacuum has no suction because it will not pick up hair or lint from the carpet, when the problem is the belt is stretched and slipping and not spinning the brush roll fast enough. Replace your belt twice a year to clean carpets properly.
Dec 28, 2016 | Vacuums
My Hoover Remedy Multi-cyclonic vacuum has no suction to pick up from carpet
You either have a broken belt or a clog of lint buildup inside the vacuum.
Sep 03, 2015 | Hoover Vacuums
Does not pick up lint on carpet
I have a four suggestions. First, check the wand and see if the suction vent is completely closed. If this little vent has the slightest opening, the suction is reduced. cSecond,if that's not the case, you might want to check the brush/roller area. Threads and fibers caught on the brushes can prevent the vacuum from picking up lint. Third, make sure there are no fibers in the wheel of the vacuum head. And fourth, make sure the bag is not full! I often forget to check and back and a full bag is one of the main reasons a vacuum will not pick up items. I hope this helps. If one of my suggestions solves your problem, please contact Fixya and rate my solution!
Nov 21, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Need to clean lint out of the front cover.
You need to use a Hoover Nozzle Cleanout Tool for the SteamVac
You can find the part by clicking the link. Please give positive feedback.
Cleanout tool Link
http://www.usavacuum.com/Hoover-Nozzle-Cleanout-Tool-SteamVac-p/39514001.htm
Jan 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Our machine works 3 minutes - and then 10 minutes it does not
The usual suction problem with these things is related to a clogged lint filter. I had the same problem as you with my carpet being completely soaked. Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from tool to floor use). There is a small (1 inch square) red plastic filter on the under side. Try flipping open the little door and you will probably find it clogged with hair and carpet fibre. Clean it out and hopefully you will have suction again.
Jul 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does not pick up loose lint or fuzz from carpet.
Sounds like the belt is loose or it's not on at all. Make sure the belt is wrapped around the brush and is locked in by the metal.
Mar 15, 2009 | Hoover U5753-900 WindTunnel Bagless...
Dyson o7 animal pick up problems
Hi.
If your machine is A few years old it may need new brush roller fitted.
To check roller for wear lie machine on the floor & pull back head end as if vaccuming carpet.
Now get A rule or straight edge hold this over brush roller & sole plate oppening.
Now rotate brush slowly by hand the bristles of the brush should just kiss the edge of rule. If ther is a gap you will need toreplace the roller.
http://dysonmanuals.llc.nu/
Jan 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
147 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
