Question about RCA TruFlat 27F520T 27" TV
27f530t rca television
Can you help me reset the parental cotrol code on my tv i tried all of your tips and none worked my front panel is also blocked is there a way to fix the problem and if so how do i do that please help me thank you
  • peewaddle Feb 12, 2008
    Parental Lock is on and dont know the password
    President:
  • 3,130 Answers
If you tried all of the tips, Then the front panel butoon assy. is the problem. Where did you get all of the tips for the RCA as there are several?
Posted on Feb 09, 2008
I blocked the front panel by mistake pls help
If you blocked the front panel,then you must have put in a parental lock passcode,if you cant remember that,then reply to me and i will research the back door code for this model.
Nov 01, 2009 | RCA 20F424T 20" TV
Tip
My front panel is blocked how can i reset the code any time i push a button on...
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works: Hold down MENU on the remote and VOLUME DOWN on the TV it?s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
on Feb 08, 2008 | RCA F27664 27" TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Forgot parental code and front panel is blocked how can I unlock?
Enter in either all zero's or all nine's. This is usually the lock reset code
Jul 10, 2009 | RCA 27R410T 27" TV
Need help unlocking the tv parental code
Enter 8888 as the password & then push ok.
Apr 10, 2009 | RCA 27F530T 27" TV
FPA LOCK ON RCA TV STANDAR
Unfortunately a remote is required to disable the Front Panel Lockout. This is to prevent children from circumventing some Parental controls.
It is possible however to access the Lockout with a universal remote,
which can be purchased from places like CVS, Walgreens, Kmart, etc. usually for under $20.00.
If you already have a universal remote laying around it may be just what your looking for.
Please let me know if you need any further help.
Oct 11, 2008 | RCA 27F530T 27" TV
TV RCA 27F530 27'
Has one ever been set? Or are you looking for the default code?
May 06, 2008 | RCA 27F530T 27" TV
How do you cancel parental control?
If you forget your password, simultaneously press and hold the MENU/
OK button on the front panel and VOLUME down button on the
remote for three seconds. This resets the password only and unlocks the
TV; all other settings in Parental Controls are not changed.
Page 48 of the manual.
Jan 13, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My tv will not come on because of block; my remote doese not work how do i get the tv to work
press menu button on front panel and volume down on remote for 3-5 sec.
Dec 15, 2007 | RCA 32F531T 32" TV
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
RCA TruFlat  27F520T 27" TV Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
