Question about Mitsubishi WT-46805 46" Rear Projection Television
Half Dead mitsubishi wt-46805
This TV was left behind by a tenant. No picture or sound. Power button light does come on though, and from the back left of the set comes a clicking on/off sound. Is there anything a layman like myself can check easily? I'm thinking of hauling it into a shop to get checked out, but I think $200 might be my limit before it goes to the dumpster/craigslist for parts.
  • Hallas Feb 09, 2008
    What exactly is a "yoke connection", and is it a labor cost, or parts cost?
    Is it worth it to sink $200 + on a tv nearing ten years old that, from my peeking inside, looks fairly complex?
  • Mustang69hm Mar 24, 2008
    I have the same problem. The Mitsubishi WT-46805 unit. Just out of nowhere it does not come on just a click then the green light comes on next to the power button stays on for approximately 3-5 seconds then clicks again and shuts off. I am fairly knowledgable at working with electronics and how to use a multimeter if someone has a wiring schematic they could post up or something I can check the parts that are most likely out. Thanks ~Heath
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
This condition can be caused by multiple failures, however this unit has chronic bad yoke connections. Difficult repair for a layman but not for a tech or shop. Most likely 200 to 250 for that repair. Other more serious failures sure to cost more.
Posted on Feb 09, 2008
  • Les Price Feb 09, 2008
    Each CRT has a yoke and it is a very complex repair that would require a tech. The cost would be mostly labor and I'm not sure I would invest over 200.00 on a unit of that age.
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi big screen tv model no. wt-46805 year2000
Replace the convergence amp ICs. also shck the resistors coming out of the ICs
Jan 30, 2008 | Mitsubishi WT-46805 46" Rear Projection...
MITSUBISHI WT-46805 No Volume
Sounds like audio output IC is bad.Hope this helps. It is on the center circuit board on a little heat sink directly in front of the large Convergence heat sink. It is referred to as IC3E01 and the part number is LA4663. Hope this helps. Let me know if i can assist you further.
Nov 05, 2007 | Mitsubishi WT-46809 46" Rear Projection...
The Green light of Death
I was told for mine that the cpu is keeping a relay from turning on.the shop said they would have to find out what is makeing the cpu want to do that. could be a $100 - $1000+ repair.
Oct 24, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Mitsu 46805 - No picture
this model has loose connections on the yokes remove the front speker gril and a small cover wigil the wires alittle and see if the pic comes back on if so solder the bad connections and put fresh solder on the verticl ic too
Oct 18, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
