posted by mesclun on Feb 09, 2008
Hello. I am trying to fill a bobbin. I can release the clutch, but when I press the pedal nothing happens the bobbin winder moves when it is engaged. Is there something inside that is not happening? Thanks.
Comment by mesclun, posted on Feb 09, 2008
thankx i will check it out. the thing is my machine is not very old.
Best Solution
As I understand it the winder will only work with the stop motion tight and not when it is undone to wind a bobbin, when you loosen the stop motion there is slight give in the balance wheel and I think either the winder rubber is worn down or the winder itself needs adjusting, you will need to get into the top of the machine for this.
Rating Locked! (?) mesclun has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Necchi 3102 Mechanical Sewing Machine
Email this problem
Email this problem
Can you Help with these Sewing Machines problems?
Necchi 3102 Mech. Sewing
In your response to... Answer This...
Bought an estate sale Necchi
Bought an estate sale Necchi... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
