5o' rear projection no sound
Turned tv off this am. everything ok.turned tv on this pm.no audio?
  • Anonymous Jul 11, 2008
    SONT GRAND WITH NO SOUND.
  • Anonymous Oct 05, 2008
    I am having the same issue. You can hear it, but at full power, it is very quiet and muffled. One speaker acted like it went out and the second one went. I went to change the speakers and found out that this was not my problem. I am able to use my receiver and surround sound to get audio, but no luck on the audio directly from the TV. Is there a way to check the output is bad?
    Below is the model number.
    65HDX82 65 in. Rear Projection HDTV-Ready Television
  • 8,617 Answers
Sounds like audio output IC isfaulty. What is the model number of your set?
Posted on Feb 09, 2008
My tv turn on, I see picture but dont have any sound. How can I have sound?
Some TV's have internal speakers on/off in the audio menue.
Also if you have a headphone jack does it work ?
Jun 25, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
I came home to find NO VOLUME on the tv now. Everything else seems ok
I will presume a few things:
1. you have tried it via the coax or cable fittings and also rear audio and video inputs.
2. speakers (in the menu) are not turned off.
3. if you are using a cable or sat box you have hooked something direct to the set for sound.
If this is a 2001 or 2002 model there may be another issue.
confirm the date of production and I may be able to tell you exactly what is wrong (date is on back of set).
Steve------aka SD TECH
Sep 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I turn my TV off everything was ok..then I turned it back on but no picture sound only ,,,why ?
you might try do a hard reset. turn tv off unplug it hold power button on tv for bout 30 sec. then plug it back in. i had a similar problem and this worked for me.
Oct 08, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Sound is out ... everything else is working fine
let us try a simple approach....
disconnect everything from TV... plug tv in a/c outlet...turn TV on...do you have sound now? check MENU of course...if still NO audio then we have isolated the problem to the TV .
you can lose audio from a bad wire , a bad cable box(believe it or not)., a loose wire, a button being engaged etc......seeing as you have a Zenith...that 1 is known for bad AUDIO IC on circuit board( a linear IC with staggered legs into board( careful with FOIL when replacing IC!!!
May 19, 2010 | Zenith IQC50H95W 50" Rear Projection...
Kenmark 20" LCD TV Sound but no picture
My Kenmark Tv Switches its picture off if the PSU voltage drops. Audio is OK but picture does not return as PSU voltage goes back up. PSU's are about £10 online !2Volt 4A Might be worth a punt
May 04, 2009 | Zenith IQC50H95W 50" Rear Projection...
Cannot get audio
Make sure the center channel switch located on the rear jack panel is not switched on. The only sound you'll hear when this is turned on is muffled bass or no audio at all.
michtech
Feb 12, 2009 | Toshiba 57HX81 57" Rear Projection...
NO AUDIO OR AUDIO GOES IN AND OUT
problem is defective part on audio bd., either audio I.C. or a bad resistor or capacitor on the output side of the I.C.
Dec 30, 2007 | Sony KP-53V90 53" Rear Projection...
No audio
What type of sources might you be using, and do you use the RF input for anything?...accordianman
Oct 01, 2007 | JVC AV-48WP74 48" Rear Projection...
My phillips 5o inch rear projection tv
I'd really like to see what you're describing here, but it sounds as though the SSB (small signal baord) is failing, Philips p/n#Ph3912725871 It's a vertical board on the left side viewed from the rear of the unit. It's clearly one for the shop... Good Luck Bill
Jun 06, 2007 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
