Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WSB55 Model wsb55 s/n 105411 mfg. Jan. 2003 TV will not turn on and green power light flashes when tv is unplugged and then re-plugged in.
  • 4 more comments
  • artistb Feb 15, 2008
    WS-55809 .... Will not come on.... LED lights...clicks like it is going to come on then goes out. When you plug it back in the LED flashes 3 times.
  • rockboy Feb 21, 2008
    Tried the capacitor fix - still not working. Any ideas????
  • cbreer Mar 02, 2008
    I have the same problem... You can hear a click in the left rear of the TV and the green LED flashes when you hit the power button, but the TV does not turn on! Any solutions?
  • hippiespace Oct 20, 2008
    Dude I tried the cap fix as well and had no luck did u get it working and how?
  • James Stramer Dec 30, 2008
    WS-B55 Mine flashes green all the time can somone help
  • jimily Jan 05, 2009
    I actually got my TV for free from a lady who had this problem for years. She was able to afford to send it in to the shop to "fix" it over and over, and she gave it to us because she was tired of fixing it. I brought it home, plugged it in and let it sit for about 4-6 hours and then it worked. I changed the power saving settings and I didn't have a problem with it for awhile. Recently, it got to where I couldn't turn it off because I couldn't turn it back on until the power indicator stopped blinking. Now my TV has crapped out completely. It won't turn on, I unplug it and leave it unplugged for days, plug it back in and nothing changes. I leave it plugged in while it's blinking and still nothing. It has been on the fritz for about a month now. Any suggestions? I would hate to waste a perfectly good free 55 inch HDTV. LOL!!
We had a TV fixed Mits WSB55 that was hit by lighting. Now turnes on then dies.
Talked to a friend that lives in zip 32256
and he said try Advance Electronic. We did and are very happy with <a rel='nofollow' href="http://www.aetjax.com"> tv repair </a>they found bad caps in power supply.
Posted on Aug 25, 2010
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 21, 2008
WS-B55
If you check your owner's guide, it'll tell you that if the green LED is flashing, wait a minute forit to turn off before retrying power button.
I know this won't be a remedy to many, but it let me power up the set long enough to see it blooming which is a good indicator of the problem.
Posted on Nov 15, 2008
Well cannot get error codes to work....only after plugging in...the Green LED flashes 3 times....Tv will not turn on????
Posted on Feb 23, 2008
4 Suggested Answers
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Apr 03, 2009
Slinteriors
  • 8617 Answers
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Continuous green flashing light
ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Jul 31, 2009 | Televison & Video
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Blinking green light, will not power up
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
1,356 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
