Question about Sony KP-61V90 61" Rear Projection Television
Sony rear projection tv kper43m31
Remote control works fine can,t get into service mode thank you,shan
Ehm... pressing power will turn off the set.. don't it?
Posted on Jun 29, 2008
  • 84 Answers
All Sony projection TVs have the same remote key sequence to get into the service mode:
display - 5 - volume(+) - power
C-Dog
Posted on Feb 10, 2008
Remote Control for kp-57ws520 turns tv off only but no other functions work ... Ideas??
first be sure it is in the TV mode then try new batteries. If that doesn't cure you will need new transmitter
Mar 08, 2015 | Sony KP-57WS520 57" Rear Projection...
KP-46WT500 46 in. Rear Projection HDTV-Ready Television convergance adjustment
Try using the MENU button on your remote control to go into the TV picture settings menu. Change the mode to NATURAL, You can also try to manually adjust the color in the COLOR SETTINGS mode.
If that doesn't work, check out the handy troubleshooting chart in TV color problems and see if another solution will work. I hope this helps!
Sep 13, 2012 | Sony KP-46WT500 46" Rear Projection...
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
I REPLACED LAMP. TV TURNS ON THEN OFF. POWER
hello make sure the lamp is fitted securely and the lamp cover as well
regards
shan
Mar 27, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony 46in projection tv
To reset this unit start with pwr off. Then on oringnal remote press the display button, the number 5 button and then volume up button and then hit the power button this will take you into the service mode menu, Press the number 8 key and then hit enter, this will set the unit back to factory specs. The set should turn off itself and then power on itself to channel 3, All user setting before this procedure are reset to factory mode..
Please leave comment THX
Nov 04, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Remote stopped work for my kp-61hs10
Sounds to me like a problem in the tv, not the remote. A short maybe, or a bad connection somewhere.
Dec 22, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-48S65 48 in. Rear Projection: fine tune convergence
you will have to go in the service mode. be careful as you could damage the tv if wrong settings are changed. with the tv off push on the remote display 5 vol+ power. now hit the 1 button until you see pje fdis on the upper left. now push the 9 button to enter convergence. you should now have a cursor on the screen. usr the 3 button to switch colors. use the directional pad on remote to move the cursor and the enter button in the center of dir pad to select or deselct a point in the screen. push muting and then enter to save convergence. now restart the tv and all done
Sep 19, 2007 | Sony KP-48S65 48" Rear Projection...
Sony KP-53S35 Rear Projection TV
You will need to replace the "HA" board wich is the control panel and remote reciever (wich has failed). Here is a link to the part number and where to purchase from. http://www.partstore.com/Part/Sony/Sony/KP53S35/Sony/Sony/A1372288A/New.aspx
Apr 09, 2007 | Sony KP-53S35 53" Rear Projection...
Sony kf50xbr800
juzz i suggest that u would unplug the unit for a couple of minute the plug it back in on a wall outlet.use the tv/video button to change the video input if that button didnt work it may require service....jake
Dec 07, 2006 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony KP-61V90 61" Rear Projection Television Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
