Question about Motorola Mobility RAZR V3
When using iTap, nothing shows up
When i am trying to use iTap predictive texting, the screen shows up blank. When I use the regular texting though, it works.
  • Anonymous May 22, 2009
    you need to do the master reset and master clear. save ur data to computer and do it. it should work than.
  • 93 Answers
It could be a software issue
Posted on Feb 11, 2008
Cant change my messaging from dictionary to odinary text
To disable predictive texting on Motorola V360:
  1. Select the "Texting," "Text Messaging" or similar option on the menu screen.
  2. Choose the "Text Options" or "Options" selection on the "Text Messaging" screen. Choose "New Message" or "New Msg" if no "Options" selection is available, then press the button associated with the "Options" selection found on the blank message screen.
  3. Select "Entry Mode" on the screen. A list of options appear.
  4. Select a non-iTap mode, such as "Symbols" or "abc2." Press "OK." The iTap entry mode is disabled.
Jun 27, 2011 | Motorola Mobility V360 Cellular Phone
How to change from predictive text on my razr 3i
Press # in a text entry screen to select an
entry mode
1 Your Primary text entry mode can be set to any iTAP® mode or tap mode(indicated by 1).
2 Your Secondary text entry mode can be set to None, or set to an iTAP
mode or tapmode (indicated by 2).
123 Numeric mode enters numbers only.
@ Symbol mode enters symbols only
Jul 13, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
How do you remove predictive text on the motorola i580
While in the message screen, press the Menu key and then selectan " Entry Method "to switch among modes. Predictive text is iTAP.. so pick a different entry mode then itap
Oct 30, 2009 | Motorola Mobility i580 Cellular Phone
How do I turn off predictive text on my motorola razor?
go to create a message, then press the - key, go into entry setup then change primary to TAP. this then enables the function you require.
Happy Texting
Jan 03, 2009 | Motorola Mobility RAZR V3
Predictive text stopped working
try a master reset if that does not work you can try flashing the firmware back into the phone.
Dec 11, 2008 | Motorola Mobility RAZR V3
Itap predictive text messaging
that is how it works....ITap Predictive but if you are not comfortable with it then go back using english texting option.
Mar 23, 2008 | Motorola Mobility L6 Cellular Phone
How do i remove predictive text
go to your messages... then choose message setting... look for default text input and just choose iTap (i think???) just play around with your message setting...
Feb 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Texts random letters and then sends on it's own
have you tried to change the TEXT T9 from iTap to just ENGLISH
Dec 29, 2007 | Motorola Mobility RAZR V3
How do you turn off the irritating predictive text??
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button this will take you to message editor. Now go to Entry set up . In the Primary setup press the iTAP english and in the secondary set up select TAP English....This will work ........if you still have problem contact me
dsrinivas2007@gmail.com
Dec 27, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility RAZR V3 Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
