Question about Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
Just a couple of days ago when I turned on the TV I got the green light, followed by some clicking and a few seconds later the red light flashed 5 times. This continued. I called Philips, they had me unplug the power and everything else that was hooked to the TV, leave it off for a few minutes and then turn it back on. It didn't help. Can you help me?
  • dentistheman Jul 08, 2008
    Same problem. Power LED stays green. Something in the tv is making a clicking sound like it is trying to turn on, but the screen stays black. After minute or so the Power LED flashes red. Also I cannot turn the tv off. If power is connected it stays on. Tried unplugging it overnight and plugging it back in, but it didn't work.
    Problem Solver:
  • 12 Answers
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Posted on Aug 08, 2008
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Open Questions:
See all Philips 42PF7220A 42 in. Plasma Television Questions
Philips 42PF7220A 42 in. Plasma Television Logo
359 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
