Panasonic tv don,t turn on
Tv dont turn on,no light,fuse fine,was working fine thia am.
  • t31067 Feb 09, 2008
    no power in tv, power outlet is fine,all external elements looks fine.Already tried after 30 minutes off no change, don,t see any reset button.it is 1 1/2 old.no smell of any burning wire etc
    pv-df 2036m
    Genius:
  • 3,422 Answers
ONE: Check the power strip to make sure it has not tripped out. Mostly they have a reset button somewhere on the bar. You can test the tv in another outlet around the house or use a lamp to verify you are getting power.
TWO: Also, check the line cord. Wiggle it near the molded ends which is where the greatest of open circuits happen.
THREE: Unplug the tv for 30 minutes and try again. This will reset the power protection circuit.
FOUR: If all above does not get you anywhere, then the problem is likely an internal failure of one of the key sections of the tv. The power protection circuit is constantly monitoring the current drain and shuts the set down when too much current drain is detected. Culprits are the deflection circuits (including the high voltage generator call the flyback in the horizontal deflection amplifier), audio amplifier and main power supplies.
FIVE: This set is getting along in years. If the problems turns out to be an internal failure of one of the sections above, then replacement of the set may be the better choice. If you must replace the power transformer, for example, in your set the cost will be upwards of $200 to $250. Replacement of the flyback will run around $100.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 09, 2008
  • Priya darshan Feb 09, 2008
    The only solution is to call a technician and get it repaired so that you don't face any problems in the future..
    There can bee reasons for the TV not turning on.There are many circuits which may have burnt.
    If you have any other problems please ask me..
    President:
  • 1,944 Answers
Could you please tell me the exact model of your TV? Thanks!
  • Damen Wong
    Damen Wong Feb 10, 2008
    Do you remember what was the last thing you did on your TV before it stopped working? Has the TV experienced any power surges?
  • Damen Wong
    Damen Wong Feb 22, 2008
    Try leaving it out of the power more than 30 minutes. Try a few hours.
I HAVE A PANISONIC HDTV1808I PROJECTION TV MODEL PT-51HX42F ITS A 2003 YEAR IT WAS WORKING THEN WENT TO TURN IT ON AND NOTHING ITS POWER RED LIGHT BLINKS 5 TIMES THEN PAUSES AND STARTS BLINKING THE SAME...
You need to replace the "Lamp" check Google Shopping for pricing. Enter your TV model # and add the word "Lamp" Make sure you get a Phillips or Panasonic lamp don't get a Chinese knockoff. They don't last!. Hopr this helps.
Jul 02, 2011 | Panasonic Televison & Video
It won't start. Could it be the lamp?
I have a 36" Panasonic TV (manufactured in 2004) that suddenly stopped working. It was working fine up until I turned it off one evening before going to bed. The next morning, when I went to turn it on, NOTHING. No power indicator light, NOTHING. I'm a big "do-it-yourselfer", so I took off the back cover of the TV case and discovered that it was just a burnt-out fuse. It is a small "snap-in" glass fuse that should be mounted to a circuit board near the area where the main power chord enters the back of the TV. I found the replacement fuses at Radio Shack. The fuse came in a package of 4, for $2.99. Cheap fix and works great! The biggest problem I had with the fix is that the TV weighs 386 lbs., so I had to get help lifting it out and back into the entertainment center.
BK
Dec 08, 2010 | Panasonic Televison & Video
Honda cbr 929 headlight and turn signals dont work and fuses are good
headlight and turn don't come on all fuses are fine power to all connectors no short,how are these lights grounded or cdi trouble tell me what imissed thanks
May 22, 2010 | 2000 Honda CBR 929 RR Fireblade
Panasonic Plasma TV won't turn on
my television will not power on at all no lights no anything, Worked fine the day before
May 21, 2010 | Panasonic TH-50PV30 50 in. Plasma...
Green light blinks.. wont turn on.... standby pwer appears normal.. ihvt and hor output check fine
*This was posted in another thread as a solution to your problem, it would seem that this procedure is for the TV savvy, and I would not recommend that you do this procedure, and that you bring it to a TV repair shop. Or if the TV is still under warranty that you turn it in. But if you are planning on following these instructions I wish you luck, and make sure you follow them to the word so you don't mess up your TV even more.
Found that the thermistor/temp measuring device is suspect, noresistance across legs. There is a label there that says F701 seeservice manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the backpanel, etc. Also think I had to splice in the fuse or something. was awhile ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Jul 15, 2009 | Panasonic Televison & Video
Panasonic CT-32SL14 flat screen tv stopped working
We played Wii sports and fit for few hours than tv started to flicker and change colors to green and black and white. We shut down Wii and not TV screen doesn't show any picture. The power is there and the sound... but the screen is just blue. Any one experienced anything similar?
May 20, 2008 | Panasonic CT-32SL14 32" TV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
