Question about Toshiba TZ50V51 50" Rear Projection Television
Screen Where cab get a replacement screen?
  • Toshiba Master
  • 8,617 Answers
I have access to a few screens 50 inch. However you will need to measure your screen top to bottom and side to side. Let me know those dimensions and maybe I can help you.
Posted on Mar 11, 2008
  • charlow7 Jan 08, 2012
    Would you happen to have another screen? I am in need of a cover screen. Please get back to me asap thank you
My philips tv 40pfl4706/f7 video looks l IIke it is burn in. The pervious image appears in the back ground and v the colors are off. Cab replacing the led driver card correct this? Thank you Mike
It is a display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 09, 2016 | Philips Televison & Video
Tip
What to do if you want to start a corrupted win 98?
If ur Win 98 system has been corrupted,means only the windows 98 screen appears and then a blue screen appears or after that the system dosnt start or restart follow the following steps:
1. at the time of POST (i.e when u hear the beep sound or when ur monitor shows the first displays) press the F8 key continuously . then select the option Start in Command prompt only
2. in command prompt type C:\>cd windows\sysbckup ( assuming c: is ur system or root directory)
3. then type c:\windows\sysbckup>dir *.cab
4. now select the file depending on the date closest to the date when ur system was operating fine( the file name will be like RB001.cab )
5. now after selecting the file type in the command prompt c:\>windows\sysbckup>copy rb001.cab ..(assuming the file name as rb001.cab)
6. then type c:\windows\sysbckup> cd\
7. then type c:\> extract rb001.cab/e
8.now restart ur pc
happy computing
on Jun 01, 2010 | Computers & Internet
How do I replace the oil pickup tube in a 1998 Ford F150?
remove oil pan unbolt pickup tube and screen from engine block an oil pump if your to replace and i would.-. prime oil pump with oil by putting in screen and turning shaft till oil comes out block side and bolt back up and install oil pan with new gasket and fill with oil and start up with idle and watch oil pressure till it comes up to normal, i would change oil filter also before starting there probly is a gasket between oil pump and block
Jun 25, 2011 | 1998 Ford F150 Regular Cab
I HAVE A 1999 F150 REGULAR CAB 2 WHEEL DRIVE AND WHAT IS HAPPENING I NOTICED LAST NIGHT WAS THE OIL PRESSURE GAUGE WAS ON NORMAL AND ALL OF A SUDDEN DROPPED TO LOW AND WARNING LIGHT COME ON THEN IT GOES...
A failing oil pump.. but more likely a clogged pickup tube or screen.. can cause this once you get above a certain rpm..the pump can't keep up with demand so to speak. .
Drop the pan..clean the pan..inspect for solids etc.. .. remove the pickup tube/screen.. clean or replace the pickup tube and screen..those parts are generally pretty inexpensive.
Of course it could be the sending unit.. or a bad ground/short.. yet depending on how well the rig has been maintained..or operating environment.. sludge and solids blocking the pickup tube and screen could be the culprit.
It would never hurt to drain and drop the pan.. new gasket.. new pickup tube and screen..clean the pan.. new filter.. new fresh oil.. some recommend sea foam... just follow the directions.
Best of luck!
Apr 22, 2011 | 1999 Ford F150 Regular Cab
Where is a/c filter located in a 2007 dodge megacab 4 x 4 diesel 5.9 liter?
They do not have an a/c filter. The mega cab does however have a screen on top of the hvac unit that is used for the airflow to the rear vents. The screen was removed in some cases to improve airflow to the rear vents. The instrument panel must be removed for access to it.
Apr 20, 2011 | 2007 Dodge Ram 2500 Mega Cab Laramie
Need to know how to replace backlight on hp ze4900
remove the keyboard, screen cable and screws, the open screen by removing small rubber cabs.
you can see the light behind the screen
Dec 30, 2009 | HP Pavilion Ze4900 Notebook
I dorped my phone and cracked the screen now the screen has gone black
You have to replace the screen with a genuine one.Contact your nearest Nokia Care Center
Dec 21, 2009 | Nokia N81 Smartphone
Unit not powering up
You have a defective LCD screen that makes a short circuit (thats the flashing green led)
Mostly the upper LCD screen is the problem.
You cab replace the LCD screen by buying one (ebay) and use a manual found on youtube but you need to have the skills. If not, please find someone that can repair it for you
Apr 26, 2009 | Nintendo DS Lite Console
Toyota 2008 Prius Touch-Screen
Problem is resolved,
I pulled & giggled a couple of fuses, found one fuse that had an extend fuse container was probably not quite seated right. Will notify dealer & replace several working fuses with new. rr
Mar 19, 2009 | 2008 Toyota Prius
Toshiba TZ50V51 50" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
