Question about Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001)
Speedstream SS2510 Ethernet Router
I have the aboue router. I have lost the manual and any disc support. Where can I get replacements?
George
Try Speedstream.com and specifically:
http://kb.efficient.com/display/1n/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.9983179
Posted on Jun 19, 2008
I have the speedstream 5100 modem. I just replaced my xp machine with a windows 8 and I can't get to the internet now. It tells me ethernet doesn't have a valid IP configuration. Any sugges
If you do not have a router you have to reboot the modem first, Modems pair with one device at a time using its MAC address, using a router allows you to add remove computers to your internet access without rebooting the router for every device because the modem pairs to the router and the router shares its internet with your other devices.
Jan 28, 2013 | Efficient Networks SpeedStream 5100 Modem
How do I discover or reset the password
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Dec 14, 2011 | Efficient Networks SpeedStream 5200 Modem
Am trying to find out if can use a router with speedstream 5100 Part # 060-E142-A02(modem access code 2038304758?
Yes you can. Connect the ethernet cable (circled in the image below) from your speedstream modem to the Lan port on your router. Hope this helps. 1c801d4.gif
Jun 24, 2010 | Efficient Networks SpeedStream 5100 Modem
I need the driver download, i've lost my disk.
Can you please tell me is it a router or Ethernet card. If it's router I think no need the driver. Just connect the router to you PC in default network configuration. and type http://192.168.254.254 and press Enter. put Admin as default admin user name and Admin as default administrative password. then setup the necessary configuration.
For further please be with us.
Good Luck
Nov 30, 2009 | Siemens SpeedStream 4200 (13A4200001)...
SPEEDSTREAM 4200 MODEM CONNECTED TO WRT54G ROUTER WIRELESS DONT
turn on the wireless option in the router...
plug your computer into the router type in
192.168.1.1
username: admin
Password: public
go to wireless tab
turn it on
END!
P.S.
Also you have to be in range!
Sep 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Speedstream 6520 isnt broadcasting a signal to connect to
if the pwr light is on, its not a pwr issue.
if the ethernet light is on you should be recieving a signal.
sometimes you may need to reset your modem and refresh everything in the case of pwr outages or unplugging etc.
i suggest calling your internet service provider and having them walk you through a manual reset of your modem
Jun 27, 2009 | Efficient Networks SpeedStream 5100 Router
Is the speedstream 4101 (4100b??) router wireless?
?ctx=uc_en_0_141386_rArNrNrNrN&fil= SpeedStream_ 4100
Well M8, its not wireless!
Its supports only ethernet via ethernet cable or usb
Nic
Jan 30, 2009 | Computers & Internet
Factory defaults on ss2510 powerline router
Look for a small reset button. It would typically be concealed in a small hole where it can be pressed with a paper clip. Try pressing the reset button for about 15 seconds, then release it. If this fails to reset to defaults, turn off the power...press the reset button....turn on the power while holding the reset button in...continue to hold the reset button for about 15 seconds.
Good luck...and I hope this is helpful!
Jan 22, 2008 | Efficient Networks Siemens SpeedStream...
Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Logo
249 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
