Question about E-Machines (T2958) PC Desktop
E-Machine constant reboot
I know someone who has an e-machine T 2958 that reboots constantly and the error message that comes up indicates that there was a hardware change but nothign was changed.
When I try to start in safe mode it does the same thing.
Any thoughts?
Thanks.
Andrew
  • papi285 Mar 13, 2009
    machine constant reboot
  • scnn_nck May 11, 2010
    bad power supply just read that !!!
    Novelist:
    Scholar:
  • 108 Answers
I can speculate on a lot of things but the error message (specifically) gives me a place to start that might be in your interest.
Otherwise just reformat and start over (painful). Also...fyi...a lot of "emachines" have problems. I have replaced motherboards at the ratio of 5 to 1 and I fix machines as a part time exercise. Hope this helps....Tango.
Posted on Feb 09, 2008
My hp Pavillion dv6 laptop can no longer use Constant Guard which Comcast supplies. Also Quattro Pro quit working midstream. How do I fix it?
More then likely running System Tuneup replaced critical files that Comcast Constant Guard and Quattro Pro uses... I recommend doing the following three steps but only if you have the Original or backup copies of the installation disc/media for both applications: 1) uninstalling the Comcast Constant Guard application 2) then do a normal shutdown and reboot once it has rebooted 3) install the Comcast Constant Guard once that's done and successfully do the same three steps but for the Quattro Pro application
Jan 02, 2015 | HP Pavilion Computers & Internet
My copier machine Toshiba 7230 have error code CD10 when I'm copying. Sometimes The message "reboot machine" appear. How to solve the problem?
try pulling out the plug if that doesnt work try pulling the battery I believe by shutting it down you can reboot it. GoodLLuck to ya.
Dec 19, 2012 | Office Equipment & Supplies
We have our machine on a network, most computers are Windows 7, we have the correct drivers. However when trying to print PDFs we are getting a constant message of "Reboot Machine". This is a new...
just check ur sharing settings , if they r perfect den try to reinstall the drivers for ur printers on remote machine... if dis doenst solve it, den recontact me..
Mar 01, 2011 | Office Equipment & Supplies
Constant number 8
I called GE. They said unplug phone lines, then unplug power source, wait 10 to 15 minutes, then reconnect in the same order. If that does not reboot the answering machine, then buy a new one.
Dec 11, 2008 | GE 29875GE Digital Answering Machine
Dell Precision 490 constant reboot after ghost image completed
Hello-
I figured out how to ghost a Dell Precision 490 with a 32 bit Windows XP Image! Like you I had the same problem where it would constantly reboot after I imaged it with an existing 490 image. The answer is actually very simple. Boot up your Precision 490 and hit F2 to enter the bios. Select Drives and then SATA Operation, change it to "Raid Autodetect / ATA". Reboot the 490 and re image the machine, it will now work!
Dec 01, 2008 | Dell Precision Workstation 490 - MT -...
Constant Rebooting and System Error Messages
I suspect you could have a heat sink fan not working remove side of case and when you turn computer on check fans heat sink and video card are working
With computer OFF
remove heat sink fan and check that the heat sink is not clogged up with fluff and dirt.
I regularly clean both fan and heat sink every 2 months also check the fan in power unit and blow it out
Aug 16, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
Jul 24, 2008 | Office Equipment & Supplies
CanonIR 5570 Copier reboots then jams at sorter
Sounds like the sorter connection between the two is poor or disconnecting, check the cable from sorter and power lead to the sorter are secure.
Check switch that machine uses to know when sorter is engaged is closing proberly/not bent
Check sorter indicator lights (if any) after reboot,
Try running lead to it from elsewhere in case there is too much drain or something weird with power supply where you are
Jan 12, 2008 | Office Equipment & Supplies
E-Machines (T2958) PC Desktop Logo
186 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
