Question about Maytag MDB7100AWB Dishwasher
MDB7100AWB STOPS AFTER 3 SECONDS OF RUNNING
WHEN I PRESS ANY OF THE WASH BUTTONS ON THE UNIT, THE TIMER SHOWS TIME LEFT, BUT NOTHING ELSE HAPPENS. EVERY FEW MINUTES IT SOUNDS LIKE THE UNIT IS RUNNING FOR ABOUT 3 SECONDS, THEN STOPS AGAIN. THE TIMER DOES COUNT DOWN. Press any wash button, lights illuminate and nothing happens. No timer
  • 1 more comment
  • ecobob Feb 09, 2008
    Wife closed door and all lights began to flash.
    I have a TABLE prepared showing what happens but this poorly designed system will no accept it. Can send via email.
    Since then, the following table indicates action but nothing happens:
    Notes:
    Bottom of washer is filled with water. Attempted to depress “Drain” and nothing happened.
    Wash = wash lamp is on Light = Light lamp is on San = Sanitary lamp is on
    Dry = Dry lamp is on blank = lamp is off
    ___________________________________________________________
    I have a table prepared showing time based information but this poorly designed system will not accept it. I can send by email.
    _____________________________________________________________
    Notes:
  • Anonymous Mar 25, 2008
    dishwasher fills tub with water then stops after a little while light wash and clean light flashes. but nothing happens. and water is still in tub
    Genius:
  • 3,422 Answers
You may have a bad timer (under the knob) the main control unit.
If you can remove the timer by removing the plastic cover and check the timers contacts, if they are burnt or broken then replace the timer. If you cannot access the inside of the timer...it still may be needed to be replaced.
if the motor only runs for a few seconds, and then shuts down the usual problem is the motor overloading and shutting down.
This sounds serious. you may want to call Maytag and have there people check out the machine.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 09, 2008
    Novelist:
    Scholar:
  • 108 Answers
1. The Maytag sevice centers, if close, are "great". You describe the problem and they supply the part. If far still give them a call.
2. The problem is probably the control. It's a simple fix. Just replace the part. And you can order the part from the service center. Takes 10 minutes.
Tango
How do i set the time on my oxo digital timer
OXO doesn't provide a link to download the instruction booklet for this model, but I own it too, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Mar 10, 2015 | Oxo Good Grips Digital Timer
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
To set timer:
To time activities:
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Sep 15, 2013 | Oxo Hardware & Accessories
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Mar 26, 2013 | Oxo Hardware & Accessories
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
I have pressed reset on my grasslin qe1 timer and now nothing will work on it
Grasslin qe1 and qe2 manual does not show troubleshoot section.
http://www.grasslin-controls.co.uk/assets/graphics/static/QE1-QE2_GB%20instructions.pdf
1) Remove power to unit and see if it will reset.
2) Press reset and hold button longer
3) Manual says: SLIDE SWITCH MUST ALWAYS BE LEFT IN "RUN PRESET PROGRAMME" OR, "RUN OWN PROGRAMME" POSITION, OTHERWISE THE CLOCK WILL NOT RUN, AND NO SWITCHING WILL OCCUR.
4) Timer has stopped working. I test timers, and they all stop working one day.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 04, 2011 | Hardware & Accessories
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
My dishwasher will not start. The 3 second button light is on and when I press it nothing happens . I try pressing any other button and nothing works
It sounds like you have "locked" the dishwasher. This was an added feature that most people never wanted since it only seems to be set by accident.
Try pressing the 3 second button and holding it down for at least three seconds. This should turn the light off. Drove us nuts the first time it happened. If it doesn't turn off then I guess it is broken.
Jan 03, 2010 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB Dishwasher Logo
185 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
