Question about Dryers
Installing a dryer motor. Ge we17x10010
I'm replacing a GE 17x32 with a Ge 17x10010m but I don't know the connection sequence. to the centrifugal switch. help is much needed and deeply appreciated!
  • Anonymous Mar 01, 2008
    I need to know which terminal to connect yellow wire, from the belt tensioner switch, and the bluish wire
  • Anonymous Jun 27, 2008
    ge dryer model # DDE7500GALAD old dryer motor Form t new motor form V old switch 2= violet / pink wire ,4= yellow ,5 = light blue, 6 = brown,3= no wire, 1= thick black new switch has terminal 1 , 3 , 5, 6 black wire from motor , 7 orange ,8 light blue , grnd how do i wire this
4 Suggested Answers
  • 1122 Answers
SOURCE: replace power cord on GE cloths dryer
just remember on a 3 wire cord(if it is gray) the middle wire always goes on the middle of the terminal,the 2 outside wires get mounted one on each side on the terminal broke,if it is a 4 wire cord the white goes on the middle of terminal block,the red and black get mounted one each each side of the terminal block(it does not matter which side you put the red or black wire they are both 120 volt) the green wire gets mounted to the cabinet where ever you can mount it(to metal) your done-mike
Posted on Mar 24, 2009
protek480
  • 1723 Answers
SOURCE: Replacing the motor in an old GE dryer
What kind of help do you need, the motor?
Posted on Aug 05, 2009
Macmarkus
  • 2605 Answers
SOURCE: I sent a question on 5/2, was charged a fee and
Hello, Welcome to FixYa.
I've attached an image of how the kill switch/belt switch should be connected to the motor in regards to GE dryers.
Contacts 1 & 2 are for heating and close after the motor starts.
Contacts 4 & 5 (& 6) are for the start-run windings and open to run through a centrifugal switch in the motor...this is when the run windings and heating contacts close.
The kill switch should be connected to #5 on the motor and the other side of the switch typically (depending on pcb or mechanical timer) goes to the timer.
example, (let me know if it's too small)
Hope that helps you move forward to getting the motor wired correctly. I realize many times the replacement motors come with alternate wiring, however through determining which contacts are open or closed in the "run" state should verify where the wires go even if the switch is numbered differently.
Let me know how you make out and I'll see what I can do to help in whatever manner I can.
Regards,
Macmarkus :)
Posted on May 14, 2011
GE dryer model dwsr405eb0ww has intermittent heat problem associated with centrifugal motor switch. Interior drum light goes off with door open when centrifugal switch disengages. This is intermitte
First thing I would do is un-plug the product and remove the line cord access plate and check the terminal block/cord connections, a lot of times the installer of the product does not get the terminal block 'nuts' tight enough and it either burns up or cause erratic operation. If this checks out ok check your home electrical supply system.
Jan 09, 2015 | GE Dryers
Manual for ge dryer m460-g
_ _ _ _ 4 6 0
can you fill in the blanks?
Feb 22, 2012 | GE Dryer Motor WE17X32 WE17X10010
Dryer is not turning on. It was drying and then stopping after drying for 40 minutes and now will not turn on at all.
The symptoms you are describing are classic of a motor failure. The motor getting weak would run for a while then overheat internally and shut down. It finally gets to a point where it shuts down and the internal windings of the motor will not reset.
The solution would be to replace the motor, the part number is WE17X10010 for the most common one used, you would have to verify this number with the local parts supplier there for your model. The price is about $135.00 for the motor alone, to hire a technician to install would add about another $150.00 to the cost of the repair.
I know this is not what you want to hear but unfortunately that is what is happening.
Apr 18, 2010 | GE DBSR453EBWW Electric Dryer
I have an old GE dryer model DDG5380valwh. When try to start it it just hums. What should I do?
** ALLWAYS unplug a dryer before working on it.
Humming means the motor may not be turning.
The motor could be 'capacitor start'. Replace the capacitor.
The motor could be centrifugal start. Remove the belt. Still won't start? Replace the motor.
The motor bearings could be seized. Rebuild the motor or replace it.
The belt may be broken if the humming is a higher pitch. Replace the belt.
The drum may be jammed. Clean and lube the main bearing (Use Maytag Turbine oil or the recommended lube), the support wheels or the guides. Replace felt seals at the same time for best results.
Mar 22, 2010 | GE DWSR405EBWW Electric Dryer
The dryer runs without the start switch being used.
Good day,
The dryer start switch, starts the motor by bypassing the centrifugal
switch built into the motor. Once the motor is running, releasing the switch doesn't matter because the motor gets it's power directly from the timer to the motor thru the centrifugal switch.
Either the switch on the consul has welded the contacts, or the centrifugal switch in the motor has done the same.
To test, unplug, and access the start switch. remove one of the wires from the switch, tape it to prevent shorting, and try the dryer. If it fails to start, then it is the switch.
If it still does the same thing as before, it is the centrifugal switch in the motor.
Dec 22, 2009 | GE Dryers
I Need The Parts Breakdown For A GE Electric Motor 5KCR49TN2262Y
I check with our suppler that came up as N/A you may have to buy another unit. sorry I could'nt help
Oct 13, 2009 | Craftsman Air Tools & Compressors
My ge automatic dryer model ddp 1275 c willnt
Sounds like motor trying to start. Simplest answer is article of clothing caught in the blower wheel and thus keeping motor from turning. Second is motor switch mounted to motor is bad. Not all dryers replace motor switch separately from the motor. Third, is the motor which contains a new centrifugal start switch with it.
Aug 19, 2009 | GE Dryers
MOTOR
Here's the part numbers for the motor and the substitution version, as the older one might not be available any longer. You can order this from the searspartsdirect.com website for $169.31 and it's in stock. Please verify this is the correct part for your dryer before ordering. Hope that helps! Number: WE17X0032 Substitution: WE17X10010
Motor asm Number: WE17X0032 Substitution: WE17X10010 $169.31 In stock Quantity Add To Cart Manufacturer authorized substitution: WE17X10010 may differ in appearance, but is a functional equivalent to prior parts including WE17X0032. Manufacturer authorized substitution: WE17X10010 may differ in appearance, but is a functional equivalent to prior parts including WE17X0032.
Jul 28, 2009 | Dryers
Motor centrifugal switch bad
You cant get the switch seperate for that motor, you have to get a whole new motor.
Oct 31, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryer won't stay on
When you turn your start switch it gives temporary power to the motor and then centrifugal switch in the motor kicks in and gives power to the motor until the timer stops it or the door is opened.Your motor centrifugal switch could be bad due to poor contact or heavy linting in and around the motor.Vacuum inside the dryer specially around the motor. If it doesn't fix it you have to buy a new motor, centrifugal switch cannot be bought separately.
May 30, 2007 | GE DBXR463GB Gas Dryer
Dryers Logo
1,427 people viewed this question
Top Dryers Experts
