Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Water leaking fresh water upper tank leaks all over the place.
  • 1 more comment
  • danno78 May 06, 2008
    Fresh water leaks, the tank holds water fine when off the machine.
    I expect it might be the hose or connection.
    will check and report back.
  • Anonymous Feb 21, 2009
    same problem, but leaking rapidly. Discovered the tank is cracked where one of the one-way valves for clean water is seated.
  • Anonymous Apr 06, 2009
    tank is cracked at valve, very thin at that location
Best I can say is to not buy a Hoover product again. This is the second time in just a few months that I have had this problem with this product.
Posted on Feb 27, 2008
  • 1,673 Answers
The tank is probably cracked at the bottom and will have to be replaced, part #38777075, sells for around $60. If not the tank, then check to make sure the 2 or 3 tubes are attached to the plate that the tank sits on. Check the valve at the bottom of the tank to make sure it is there, if there push it to see if it moves up then down by itself, valve asm #43513015.
Posted on Feb 10, 2008
that is purely normal to have cleaning material in the fresh water tank as the vac picks up the dirt from the floor it should really go into the dirty pickup tank purely normal nothing to worry about
Apr 22, 2017 | Hoover Vacuums
Water tank leaks water out
Hello! Storing the solution in the water tank can cause the tank to leak. The solution tank is replaceable. Follow the link below to place an order for a replacement solution tank. Hope this helps!
Search Results
Jul 29, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Water tank valve is leaking out of the bottom of the tank. The water leaks on the floor.
it could be a cheap fix. There should be a rubber o ring that's worn or ate away by chemicals.
I'm hoping the tank isn't cracked.
Remove o ring. Contact repair place. O ring shouldn't be more than 5.00.
Sep 28, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac V2 Leaks from Bottom
That is not the solution. I have purchased several tanks and the issue is not the tank it is leaking from the bottom of the unit. can you please let me know if you found a real fix? thx for your time
Jul 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
Sep 22, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Total leak issue
There maybe a tube that has come disconnected, depending where the water is leaking. If at the bottom, then take the top cover off and check for a loose tube. If it is leaking where the tank sits on, could be a tube under that platform, or there is a rod inside the handle, when you squeeze the trigger, it pushes a diaghram where the tank sits, If the rod is going up and down, then it is probably ok, but the diaghram on the reservior asm(#48). is staying open allowing water to go thru all of the time. You may have to replace that reservior asm.
Aug 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
290 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
