Question about Philips Senseo HD-7810 Coffee Maker
Amount of coffee produced
Only half fills mug it used to fill to top - I've cleaned the filter.
  • Anonymous Feb 21, 2008
    I just purchased this coffee maker and have had trouble from day one-only once did it use up the water and make 2 cups.please help.I will have to return.
  • 2,039 Answers
You clean the filter with what vinegar you need to use descaler descaler melt calcium vinegar vinegar remove calcium in pieces that might block the machine use descaler 1 part descaler 1 part water put solution in the water tank start the machine after a few second turn it of wait 10 to 15 minute after repeat untill empty rinse very good 2 or 3 full rinse that stuff is corosif thanks for using fixya pierre
Posted on Feb 09, 2008
Bunn CW Coffee Brewer not brewing enough coffee - amount is half
Have you cleaned lately, put in an empty filter and fill with cold water with a tablespoon of white/clear vinegar. Run the brew cycle, empty pot and while still worm fill with cold water again with out vinegar. Than check filter to see how much hard water chunks are in the filter. Repeat with and without vinegar tell filter is clean. One question though is there a lot of steam coming out of the top during the brewing cycle if so inside there is a tube that may be cracked, broken or came loose, have to look inside. requires opening or disassembling unit to check. REMEMBER when taking apart UNPLUG unit first.
Nov 17, 2015 | Bunn CW Aps Single Airpot Coffee Brewer,...
Why does it only fill my mug half as much now?
try using a paper clip or long pin to clean the 2 tiny holes in the upper prong that pokes thro the top of the coffee cartage. I had the same problem and that fixed mine
or try descaling the machine
search google for descaling keurig then your model number
Sep 04, 2014 | Keurig Coffee Makers & Espresso Machines
How do I use this coffee maker its old
This looks like a mug warmer, only for the coffee pot. It has a plastic filter inside which you line up with the paper filter, on top of that goes your coffee, the pot is filled with water, plug in, turn on and let it go.
Apr 20, 2013 | Coffee Makers & Espresso Machines
My keurig seems to fill my coffee mug to the brim i dont know what the problem is everyone has issues with it not filling up enough and mine fills it up too much, when the thing is ready and i go to brew...
On the top should be right side there is this little knob so turn it to half a cup and it usually comes out as a little over half but not full so that should work out.
Jan 05, 2012 | Keurig Elite B40 Coffee Maker
I have a GB Siesta model stove top espresso pot and it only ever makes half of what it should.....I have other pots and don't have that kind of problem.....am I missing something?
The GB Siesta Oro was sold with a "Reducing Filter". This filter allows you to make half of the amount of coffee stated as the capacity of the pot. It is the mesh disc with the small stem that sits on top of the coffee after you fill the filter. If you want to make half the capacity of your pot, fill the chamber half way and use the reducing filter. If you want to make the fill capacity, fill the chamber completely and don't place the reducing filter on top of the coffee. Good luck. I hope you enjoy your pot as much as I enjoy mine. Ciao
Feb 19, 2011 | Guido Bergna Erika Espresso Machine
My coffee maker has the words de scale in the corner or something like that. Also all the lights are not coming on except the one for the most amount of coffee and it just trickles down to not even half a...
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig B60 Coffee Maker
I have the platinum Series Quiet Brewer (cinnamon color) that I bought 3-11-10 on QVC. About 1 months ago it started shuting off after filling one cup of coffee, it fills the same amount of coffee no...
sdfdf
sfsd
fsdf
ds
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
Wont brew an entire large cup
depending on how large, they fill by oz's..a large mug wont fill to the top..Depending on how strong you want your coffee..you may set for large cup the use same k-cup and the use little setting to double fill....
Dec 18, 2010 | Keurig B50 Coffee Maker
My brewer has 3 settings for dispensing coffee. Coffee cup, mug, large mug. It doesn't fill a mug or a large mug. It only goes half-way. Any suggestions how to remedy this problem?
Your problem is on the setting section of the coffee maker. Try to check if there is a visible adjuster knob or variable resistor to adjust the setting for the mug and the large mug. If there is none the adjustment is to be done by opening the system panel of your coffee maker.
Nov 02, 2010 | Keurig Coffee Makers & Espresso Machines
How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Aug 09, 2008 | West Bend (58036) 36-Cup Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
492 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
