Question about Magnum DeltaForce CB Radio
Delta force magnum radio
Noise blanker does not work
  • Mechanic688
    Mechanic688 May 11, 2010
    Herman, hello, we'll try to help you out here with your problem. There is about 3 different generations of that radio. They've been making them for about 8-10 years now, and kept upgrading them. The earlier ones did have a definate problem with the noise blanker. Magnum would upgrade all of them that were sent back to them,free of charge. The Delta has been deleted for the "new" Omega. These different mods that are available have to be done internally on the circuit board. Are you electronically able to work on the circuit board changes? Before I dive in any deeper, let me know how comfortable you are working on your radio. Thanks Mechanic
  • 3 Answers
Herman, one thing that should help is turn on the NB and also TONE .
Posted on Jan 10, 2009
Is there a diagram showing how to calibrate a magnum deltas force cb radio
I found it and so can you.Do a serch for magnum delta force radio. or go to www.bastardfairies.com
May 25, 2014 | Magnum DeltaForce CB Radio
No variable powere or am modulation
the "am" regulator is shorted. 2sa743 2sa1012or equivilent. less than $5 part..
Feb 04, 2014 | Magnum DeltaForce CB Radio
Magnum parts
email parts list needed to: saml@rflimited.com
He's a great guy and a pleasure to work with.
Mar 20, 2010 | Magnum DeltaForce CB Radio
My magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
May 14, 2009 | Magnum DeltaForce CB Radio
Magnum Delta Force Radio: The schematic does not match what is on my work bench! Schematic shows 10 tact switches,there are eight on the unit. If I trace back the leads from the rotary frequency changer...
usualy that is a sign that someone was trying to get more channels then it already has which is imposible to get any mor ok check this web site cbtricks.com go to the radio information section go to m look for the magnum radio section look for the deta force you should find all you need there. good luck with your projec and god bless you.
james morgan
morgans electronics
Feb 28, 2009 | Magnum DeltaForce CB Radio
D-104 mike wiring
Go to cbtricks.com look up radio information go to magnum use the wiring set up for the 357.
Jan 19, 2009 | Magnum DeltaForce CB Radio
Magnum delta force
pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Dec 21, 2008 | Radio Communications
Magnum s-980
all the s9 do this its not a fault
Oct 16, 2008 | Magnum 257 CB Radio
Wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Dec 23, 2007 | Magnum OmegaForce S45 CB Radio
Radio Communications Logo
135 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
