Question about Epson Stylus Photo R300 InkJet Printer
Close open troubleshooting window
How do I close this widow ,it says troulbelshooting guide stag 3
wont complete or esc.
    Genius:
  • 2,985 Answers
Re Install the sofrtware
Posted on Feb 09, 2008
Rear window will not close
If the master switch will open and close the windows and the rear switches open them, won't close them, replace both rear switches.
Jun 25, 2016 | 2011 GMC Acadia
Tip
Keyboard Shortcuts
[Alt] and [Esc] Switch between running applications
[Alt] and letter Select menu item by underlined letter
[Ctrl] and [Esc] Open Program Menu
[Ctrl] and [F4] Close active document or group windows (does not work with some applications)
[Alt] and [F4] Quit active application or close current window
[Alt] and [-] Open Control menu for active document
Ctrl] Lft., Rt. arrow Move cursor forward or back one word
Ctrl] Up, Down arrow Move cursor forward or back one paragraph
[F1] Open Help for active application
Windows+M Minimize all open windows
Shift+Windows+M Undo minimize all open windows
Windows+F1 Open Windows Help
Windows+Tab Cycle through the Taskbar buttons
Windows+Break Open the System Properties dialog box
on Apr 04, 2011 | Computers & Internet
Tip
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore...
Windows XP HELP
  • Windows key + R = Run menu
  • cmd = Command Prompt
    iexplore + "web address" = Internet Explorer
    compmgmt.msc = Computer Management
  • Windows key + E = Explorer
  • ALT + Tab = Switch between windows
    ALT, Space, X = Maximize window
    CTRL + Shift + Esc = Task Manager
    Windows key + Break = System properties
    Windows key + F = Search
    Windows key + D = Hide/Display all windows
    CTRL + C = copy
    CTRL + X = cut
    CTRL + V = paste
  • Keyboard Shortcuts
  • [Alt] and [Esc] Switch between running applications
    explorer shortcuts
    END....... Display the bottom of the active window.
    HOME....... Display the top of the active window.
  • Type the following commands in your Run Box (Windows Key + R) or Start Run
  • devmgmt.msc = Device Manager
    msinfo32 = System Information
    cleanmgr = Disk Cleanup
    ntbackup = Backup or Restore Wizard (Windows Backup Utility)
    excel = Microsoft Excel (If Installed)
    msaccess = Microsoft Access (If Installed)
    powerpnt = Microsoft PowerPoint (If Installed)
    winword = Microsoft Word (If Installed)
    frontpg = Microsoft FrontPage (If Installed)
    notepad = Notepad
    wordpad = WordPad
    calc = Calculator
    mspaint = Microsoft Paint
    wmplayer = Windows Media Player
    control = Opens the Control Panel
  • Internetbrowser
  • type in u're adress "google", then press [Right CTRL] and [Enter]
    add www. and .com to word and go to it
  • For Windows XP:
  • Copy. CTRL+C
    Cut. CTRL+X
    Paste. CTRL+V
    Undo. CTRL+Z
    Delete. DELETE
    Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE
    Copy selected item. CTRL while dragging an item
    Rename selected item. F2
    Move the insertion point to the beginning of the previous paragraph. CTRL+UP
    Select all. CTRL+A
    Search for a file or folder. F3
    View properties for the selected item. ALT+ENTER
    Close the active item, or quit the active program. ALT+F4
    Opens the shortcut menu for the active window. ALT+SPACEBAR
    Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4
    Refresh the active window. F5
    Cancel the current task. ESC
    on Oct 12, 2010 | Computers & Internet
    Distributor troubleshooting
    Your distributor may be installed backwards, or maybe just out of phase.
    If backwards, you will probably never get it to start and, of course the solution is relatively simple.
    If out of phase, the spark may be jumping to a different terminal inside the distributor cap and completely disrupting your ignition timing. See the attached video for an explanation of phasing and how to correct it on your car. (you will need an old distributor cap to drill a hole into so you can confirm spark)
    It also occurs to me that the coil you have may not be compatible with your system.
    Jul 07, 2014 | 1973 Triumph Stag
    2004 Audi Allroad Power window problem
    Possibly a faulty driver door switch. There is a function tied to switch allowing driver to open or close all windows through door switch.
    Dec 27, 2012 | 2004 Audi allroad
    Bypass code for dual xdvdn9131? is there a bypass code for this new unit?
    dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
    Feb 18, 2010 | Jensen VM9510 Car DVD Player
    Front passanger window not working.fuse checked;
    it is most likely the window motor has failed.
    Mar 19, 2009 | 1996 Ford Escort 4 Door
    Battery replacement
    not sure about US spec cars but in uk your radio is coded and you will need to put code in to radio once power is disconected.also you will need to do basic settings on electric windows if you have them??.lower the window all the way ,when it reaches the bottom keep button pressed until you hear motor click.repeat process with window closing .your widows wont auto open and close without doing this.
    Feb 12, 2009 | 2004 Volkswagen Beetle
    Sound driver
    GO TO WINDOWS XP AND DOWNLOAD A SOUND DRIVER...THE SITE WILL GUIDE YOU THROUGH..
    Oct 01, 2008 | Compaq Audio card Sound Card
    My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
    Cartridge Error 50C
    Your print cartridge has shorted.
    1. Power off your All-in-One and unplug it.
    2. Plug in your All-in-One again and turn it on.
    3. Uninstall and then reinstall your cartridges.
    4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
    Error: Black Cartridge Missing
    The black cartridge is not installed. (Install cartridge PN 82)
    Error: Color Cartridge Missing
    The color cartridge is not installed (Install cartridge PN 83)
    Cartridge Error
    Complete the following instructions:
    1. Power off your All-in-One.
    2. Use both hands to lift up the scanner unit until the scanner support holds it open.
    3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
    4. Remove the color print cartridge.
    5. Lower the scanner unit until it is completely closed.
    6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
    7. Reinstall the color cartridge and remove the black print cartridge.
    8. Lower the scanner unit until it is completely closed.
    9. If the error message occurs again, replace the color cartridge.
    10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
    11. Lower the scanner unit until it is completely closed.
    12. If you receive the error message again, replace both cartridges.
    Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
    Epson Stylus Photo R300 InkJet Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
