Question about Waring CO1500 1700 Watts Toaster Oven with Convection Cooking
Overheating oven goes to highest temp no matter what it is set for, ready light never comes on. Convection fan comes on when convection or roast.
  • Anonymous May 28, 2008
    Same problem -seems like the thermostat is not working. I unplugged the unit and opened the case . Looks like a simple part to replace -just can't find anyone who sells waring replacement parts.
We purchased a Waring CO1500 oven and the thermostat was defective right out of the box.
PROBLEM: Unable to control temperature. Would start o.k. then go up 125 degrees for no reason triggering the high limit switch...oven shuts down, recycles and starts over again.
SOLUTION: Alas, there is none. Product made in CHINA, and no parts available for replacement that we could find. Should have realized that when there was no exploded parts view included in the owners manual. Waring Products is now owned by Conair. We contacted Waring/Conair and they allowed us to return the oven to them (we paid shipping) for exchange at Waring Products 314 Ella Grasso Ave. Torrington, CT. 06790 1-800-269-6640 EXT 3135.
We are now waitng for the replacement to arrive. Wish we had a better solution.
Posted on Jul 25, 2008
Try CG Industries in Chicago, IL - they rebuild a wide variety of electronic thermostats. Their number is 630-216-5050.
Posted on Jun 05, 2008
How do I fix the Convection Fan not running/working
Make sure that the fan motor is being energized. If so, and it does not run then the fan needs to be replaced.
Apr 20, 2016 | Breville The Smart Oven Convection Toaster...
West Bend MC38ACL convection oven
Yes normally a fuse which they replace for it to heat again generally goes when over heated especially if not in a air flow area will cost about $100 - $120 to fix local electrian
Apr 06, 2014 | Toastmaster TLWTOB6 Lightwave Toaster Oven...
I just bought this oven & my daughter lost the manual that goes with it. I need to know how to use the rotisserie feature. Also need to know if the rotisserie can be used for a roast. Thank you. =)
You might not want to use it again after your first experience. Make sure you get your food balanced as the motor on this thing is very weak. I cooked 2 chickens and a loin roast when I first got it and they were no better than pan roasted and a lot more trouble.
I have posted the complete manual (3 language edition) here:
http://216.92.50.93/Manual.pdf
Dec 30, 2010 | Hamilton Beach 31197 120 Watts Toaster...
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Farberware Turbo Oven T4850- can't understand temp dial
Use an oven thermometer to test it the temperature at the various dial settings to see which is which.... Good luck!
Dec 08, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Convection setting loud noise
try going to the place u bought it and see if they can tell u what to do with it. better safe then sorry
Jul 17, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Convection mode
I would assume that these ovens have a faulty fan motor mount or it may just be a bad design. I would go with a different make or model.
Apr 26, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Not Heating
I just opened one with the same problem. The bi-metal switch / thermostat was completely burned out and melted into a small lump of metal. Unless you can get a replacement for that it might be the cheapest to go to a store and buy one new for under $80.
Aug 24, 2007 | Hamilton Beach 31197 120 Watts Toaster...
Waring CO1500 1700 Watts Toaster Oven with Convection Cooking Logo
425 people viewed this question
Top Waring Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Waring Toaster Oven Expert? Answer questions, earn points and help others
