If the heating elemnts are coming on but the drum is not spining then the motor could be bad or the belt could be broken that turns the drum. The motor could also be on a thermal overload in this case unplug the dryer or turn off the circuit breaker for 15 minutes and let everything cool down. After turn the breaker back on or plug it back in and give it a try if you hear the motor running but the drum is not spinning then the belt is probably broken and will have to be replaced.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
