Question about Nikon Speedlight SB-800 TTL Flash
SB-800 Stuck in REMOTE
I am using the SB-800 with my D200. I was using it off camera and now can't get back to TTL. When I push the mode button nothing happens.
  • brahling Feb 12, 2008
    When you say press Zoom, do you mean the four trees on the multi-selector? I was able to reset to orig defaults by using your last suggestion, but would like to be able to follow your initial directions.
    Thanks
    Genius:
  • 3,422 Answers
On your D200:
Press MENU.
Move up or down to: PENCIL menu.
Move right and down to: e Bracketing/Flash
Move right and down to: e3: Built-in Flash
Move right and up to: TTL
Move right to set it to TTL.
Sorry again for the complexity; Nikon never asked for my help. I don't reset my D200 this way. I use one of the Custom Setting Banks for remote flash, and simply select my normal Custom Setting when I want to return to normal TTL flash.
On your SB-800:
Press ZOOM and "-" together to enter the CSM settings. That's why you see a gray CSM marking between those two buttons.
Press either the + or - buttons until you see an icon that looks like a wiggly Z shaped arrow. When you see the wiggly arrow, press MODE until it says OFF.
Press ZOOM and "-" together to get out of the CSM mode. Even easier, just tap the power button to get back to normal operation. It won't turn off if you hit it while in the CSM settings.
or
You can cheat and just reset the SB-800 back to its defaults by holding the mode button and then pressing the ON/OFF button simultaneously for a couple of seconds. You'll see the display blink and it's back to normal. This is also marked RESET in gray on the SB-800. Of course this will lose any other custom settings you may have changed outside of this discussion.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 08, 2008
    Master:
    Sergeant:
  • 440 Answers
Http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
I am using a nikon D200 with a sb800. The flash is firing ok on TTL and the camera is set on 'P' however I am getting a dark picture every tme. The built in flash works OK It appears the flash/camera...
This is an excellent flash, very powerful and compact and actually more flash then what was available when the D200 first cam on the market. The two will work nicely together and I think the problem is that the SB-800 can be programmed within itself. This meaning with some cameras you program the camera for the flash output with the SB-800 you can program the flash as well. It has some excellent features like Flash value lock (which I think is set to slightly underexpose from what your question is asking) it also has Flash color information and a built in Flash compensation. Possibly the compensation or value lock are set to underexposure. I'm saying this over the camera setting because you stated that the internal flash appeared to be okay, check your SB-800 settings
Dec 27, 2010 | Nikon Speedlight SB-800 TTL Flash
Synchronizing two sb-800s with a nikon d300
You knoq the SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Regards.
Apr 13, 2010 | Nikon Speedlight SB-800 TTL Flash
I am using a Speedlight sb-800 on a Nikon D200. I cannot get the Zoom M function to change to Zoom. Any ideas?
Take flash out from hotshoe.
Can you set flash zoom manually?
When using Nikon Nikkor zoom & zooming, does flash zoom or hear motor sounds from head?
atdlee@netzero.com
Jan 16, 2010 | Nikon Speedlight SB-800 TTL Flash
Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Apr 18, 2009 | Nikon Speedlight SB-800 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon SB 800 fires but pictures reamain dark
    make sure your white balance is set to "flash" on both cameras
    Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
    TTL Multi-Flash Sync Cord SC-27
    YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
    AND SHOOT THE FLASHES IN SETTING 4A
    NO CORDS NEEDED THEN .
    BERRIE SMITH CAMERA REPAIR
    BBMW@BELLSOUTH.NET
    Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
    Sb-600 not beeping, images completely black (underexposed)
    Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
    I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
    Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
    Vivitar 636 and Nikon D200
    You won't be able to use older TTL flashguns with the D200. Since the D70, all nikon cameras have used "iTTL", and earlier DSLRs (eg D100) have used "D-TTL". Neither of these are compatible with the older TTL system used on film cameras. The newer SB-400/600/800 flashguns are all ok, and Sigma and Metz both produce iTTL compatible flashguns. The new flashguns will work on old cameras but not vice versa.
    I know this is annoying, but there were good technical reasons why Nikon changed the TTL standards.
    If the 636 has an A mode (non TTL) this should work ok, otherwise it will only work in manual (if it has a manual mode).
    Oct 25, 2007 | Nikon D200 Digital Camera with 18-200mm...
    Nikon Speedlight SB-800 TTL Flash Logo
    516 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
