Question about Hitachi 43UWX10B 43" Rear Projection Television
Color convergence red and blue will not line up/ double images
The magic focus will not line the colors. The red and blue causes double type images. Can you help.
    Genius:
  • 1,694 Answers
Repair involves some dis-assembly...replace convergence IC's
and inspect current limiting resistors for over-heat damage...
part # STK392-110 sub to upgrade STK394-160 Hitachi part # CZ 01341....you will need two....good solder technique required.
....................................................................................T.
Posted on Feb 08, 2008
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Double images, especially with red.
hi.
double image is caused by a faulty convergence circuitry. It needs repair, if you have a basic knowledge in electronics you can do it, just replace it with the new convergence kit.
Nov 22, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Double image on television with blue hue
<SPAN id=ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution>Projection <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>TV</FONT></A> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>3D</FONT></A>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <BR><BR>This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <BR><BR><B>Common Symptoms include....</B><BR><UL class=h_mi><LI class=h_mi>Screen looks 3D <LI class=h_mi>Colors don't line up <LI class=h_mi>One or more colors can't be adjusted when using the convergence menu. <LI class=h_mi>Screen is bowed or warped. <LI class=h_mi>TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </LI></UL>Here are some <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target=_blank><FONT color=#0033cc>photos</FONT></A> of convergence problems.<BR><BR><IMG class=h_mi src="/uploads/images/42D3683.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/7859B01.jpg"><BR><BR><IMG class=h_mi src="/uploads/images/E87380C.jpg"><BR><B>Here is a quick tes</B><B>t....</B><BR><BR>Using your original remote go-to the settings menu then goto the convergence section.<BR><BR>Try to adjust the red and then the blue convergence.<BR><BR>You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <BR><BR>If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <BR><BR>Note: If you TV has as flash <A href="http://www.fixya.com/#" target=_blank><FONT color=#0033cc>focus</FONT></A> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<BR><BR><B><IMG class=h_mi src="/uploads/images/69189A5.png">CONVERGENCE SOLUTION<BR><BR></B>You can see some more examples and find a fix using this link on Fixya <A href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</FONT></A></SPAN>
Aug 28, 2010 | Hitachi 53UDX10B 53" Rear Projection...
The red color seems to be sperating itself from the actual picture. The logos on screen are showing up as double image. pls advise what could be the problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 14, 2010 | Sony KP-51HW40 51" Rear Projection...
55PW9363 55 in. Rear Projection HDTV-Ready Television: My Phillips big screen has double images and doubl...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 17, 2010 | Philips 55PW9363 55" Rear Projection...
Double image and 3d color
  • Screen looks 3D
Jan 17, 2010 | Sony KP-43T90 43" Rear Projection...
Double Images Too much Red and Green
  • Screen looks 3D
Dec 03, 2009 | RCA D56W20 56" Rear Projection Television
Double image on my Sony KP 43t90
  • Screen looks 3D
Feb 22, 2009 | Sony KP-43T90 43" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Jan 13, 2008 | Hitachi 43FDX01B TV
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
138 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
