Abnormal start and stop of SATA HD
I just intalled this HD on my new DELL XPS 420 as a slave drive.
It works fine, but when I'm not accessing it, it continues to spin up and stop every minute or so.
I am concerned that this puts a strain on the motor and will speed up wear of bearings.
Is it normal or is it defective?
rpensotti@comcast.net
    Master:
    Sergeant:
  • 440 Answers
Normal turn off index services also ok thx nick
Posted on Feb 08, 2008
  • nick helpap
    nick helpap Feb 08, 2008
    do disk defrag also make sure its formated to ntfc ok
How do i fix a XPS 420 hard drive that stopped working?
You shoudl first go into your BIOS settings and ensure that the HD is registered there, compltely.
Then with the power off, open the CPU Case and look for the HD. Ensure that the jumpers are set to MAster, and that all cables are plugged in proberly and firmly. and I mean at both ends of the HD, the HD itself, and the cable to the motherboard/disk controller.
Then you should be sure that your HD didn't somehow get clobbered, such thta the disk is wiped clean, or that the critical Windows boot files are missing. If so, if you had created a boot disk for such an occurrance, then restart and hit F5 or F8 immediately after the power comes on, until you get a menu for boot. Find the option to allowyou to use boot repair and system repair on your computer.
If nothing works, then it may be necessary to start fresh and recreate your sytem from scratch.
I wish I could bring better news.
-a.
Jul 16, 2012 | Dell XPS 420 PC Desktop
RUNNING A SATA HDD ON AN IDE ONLY MOTHERBOARD
If I am not completely mistaken you have to reinstall the OS on the SATA drive on IDE. That is because the first installation was configured for connection on a SATA /PCI then now on the SATA/IDE port converter.
Sep 25, 2008 | Adapters.com Serial ATA IDE Converter and...
Ok i have two hard drives and the computer is not finding them
poss windows has fallen over you need an operating system check hdd are master and slave master first one from board go to bios set the cdrom as the default 1st boot device put operating system into cd rom should start to load operating system
Apr 06, 2012 | Dell Inspiron 530 Desktop Computer...
Hi, where is the socket on motherboard Dell XPS 420 for slave HD drive?
It looks like only has 1 IDE connector and 2 SATA connectors .
You can take a look at this topic too maybe it will help you to put a hard drive on the same IDE cable you use for CD/DVD
http://beta.fixya.com/support/t10240396-trying_connect_second
Aug 26, 2011 | Dell Computers & Internet
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
No boot device available
If the other computer would not properly access the HD as a slave, I would definitely concur that it is a hard drive failure.
Apr 09, 2009 | Dell Latitude C640 Notebook
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
