Televison & Video Logo
Posted on Feb 08, 2008
Password I need the instalation Password,
rocketeer01
Level 1:
  • Contributor 1 Answer
  • Posted on May 04, 2008
rocketeer01
Contributor
Level 1:
Answers
Questions
0
Helped
157
Points
Overide password for all GI receivers #2750 and newer - 92121 (includes GI-350I - GI-650I and older models). Try that.
How to get s soft wear to open a Toshiba Satellite laptop for free to get it to work and change the password
If you've forgotten your Windows password and you don't have an install CD laying around, there's no need to worry. Not only are there half a dozen complicated ways to reset the password, you can do it easily with the Offline Windows Password editor.
How to Reset Your Windows Password Without an Install CD Resetting Windows 7 Password No need for Windows Installation CD or...
tip
Top Four Efficient Windows 7 Password Recovery Methods
Have you ever lost your Windows password? If you have, you must know the feeling. That means you could not use your computer and your work cannot move on. So, are there some ways to retrieve your lost Windows password? Yes, here we will show you several methods for Windows 7 password recovery, and then you do not have to ask for help everywhere.
On this article we will share with you four efficient methods to recover windows 7 password, which are arrayed from easy to difficult.
Method 1: Use an available administrator account
Need: An available administrator account
If you have an available administrator account on your system, you can get your password back easily. Logon Win 7 system with the admin account, and then you can come to the Control Panel and change or delete other accounts' passwords. Just three steps:
Step 1: Click Start -> Control Panel -> Add or remove user accounts
Step 2: Choose the locked administrator account
Step 3: Click Change the password or Remove the password. And then you can change or remove the lost or forgotten password
Method 2: Use Windows password reset disk
Need: a Windows password reset disk (USB key)
Windows 7 allows us to create a Windows password reset disk (USB key) in case that we lost the Win 7 logon password. When we lose the password of Win 7, we can reset a new one with the created disk. The weak point is that you can only create the disk before losing your Windows 7 password. If you do not create that, it could not help. You could follow these five easy steps:
Step 1: When you enter a wrong password on the logon screen, a hint will appear: The user name or password is incorrect. Click OK and you are back to the logon screen. Insert the created Windows password reset disk (USB key) to your Win 7 PC and click Reset password...
Step 2: Click Next
Step 3: Choose your disk and click Next
Step 4: Type a new password and click Next
Step 5: Click Finish and your lost password should be reset
Method 3: Use third party Windows 7 password recovery software
Need:
1. A blank CD/DVD or an USB flash drive
2. A computer that has a CD/DVD writer
3. Windows 7 password recovery software
There is plenty of third party software for password recovery on Windows 7 online. Most of them are designed to create a Windows password recovery disk. With the disk you can recover your lost Windows 7 password. We highly recommend Windows Login Recovery and use it as an example. What you need to do is just three steps:
Step 1: Download Windows Login Recovery
Step 2: Burn a Windows password recovery disk with the software
Step 3: Recover the Windows 7 password with the disk
Method 4: Use Windows 7 installation disc
Need: Windows 7 installation disc
Installation disc of Windows 7 can not only install the system for you, but also restore the system. If you have created a system backup image before you created the Windows 7 password, the installation disc could help you to restore your system to the early status (the status that has no a logon password). Then you could access your computer without password. You can follow these five steps:
Step 1: Insert the installation disc to the locked Win 7 PC
Step 2: Restart your computer from the installation disc
If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You might need to change your computer's BIOS settings.
Step 3: Choose your language settings, and then click Next
Step 4: Click Repair your computer
Step 5: Select a recovery option, and then click Next
It is terrible when we lose the Windows password, but you do not need to worry about that from now on. Above four Windows 7 password recovery methods could help you to recover Windows 7 password and regain access the computer.
on Jul 21, 2010 • Computers & Internet
tip
How to choose a easiest way to Find out Windows 7 Password
An administrator password in Windows 7 is the password to any account that’s setup to access administrator level functions in Windows 7.
There doesn’t actually have to be an Administrator user account. What you need is the password to any account that can act as an administrator.
There are a few times when you will need this password. You may need an Windows 7 administrator password if you’re trying to run certain types of programs or access certain Windows 7 password recovery tools.
Follow the steps below to quickly find the Windows 7 administrator password!
1.Try leaving the password blank. If there is actually an Administrator account, the password may not exist at all!
Just press Enter without typing anything when asked for it
2.Enter the password to your account. Often times, depending on how Windows 7 was setup on your computer, the primary user account will also be an administrator user account.
3.Try to remember the Windows 7 administrator password. As I mentioned in the last step, your account might be an administrator account, especially if you installed Windows 7 on your computer yourself.
4.Have another user enter his or her credentials. If there are other users that have accounts on your Windows 7 computer, one of them may be setup with administrator access.
5.If this is true, have the other user designate you as an administrator as well.
6.Recover the Windows 7 administrator password using a Windows password recovery tool. You are able to recover or reset Windows 7 administrator password with Windows Password Unlocker
7.Perform a clean install of Windows 7. This is a last resort option. This type of installation will completely remove Windows 7 from your PC and install it again from scratch.
If you’re just curious about your administrator password, I wouldn’t suggest this extreme solution. However, if you’re needing the administrator password to access operating system diagnostic tools and this is your last effort to save your PC, performing a clean install will work.
Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Reference: How to find Windows admin password?
on Apr 22, 2010 • Computers & Internet
2answers
I forgot the administrator password, there is a malware protection software I believe. Is there any way to recover password?
You need to restart with original media disk and then you can choose reset password from the apple menu bar.
Reset password
In order to reset the password for the NComputing Administrative Console, you will need to re-install the software and reset the password through the installer. To do this, complete the following:
Launch your NComputing software installer:
  1. The installer will request a password, type anything.
  2. The installer will inform you that the password is wrong, select OK.
  3. You will then be asked if you forgot your password, select Yes.
  4. You will be prompted to restart your installer, select OK.
  5. Your password is now reset; you may Cancel the installation and access your administrative console.
tip
How to hack Windows password on your netbook / laptop using a USB Flash drive
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
on Jan 06, 2010 • Computers & Internet
Password Issue
Usually after the installation of a system on a mac you will get the welcome screen coming up and you need to enter details such as name address email and your login details such as a user name and a password. If you can't remember the password or you did not fill in a password, all you have to do is boot up with your system disk (holding down the c key) when the instal screen comes up go up to the menus and find the one that says reset your password. You will not be asked for your current password so enter a new password and it will ask you to repeat the password. Once done restart. You will of course be asked for your password when you try and install software but this is a security protocol to stop unauthorised software from installing on your machine without your knowledge. Hope this helps.
3helpful
2answers
Password to stronghold 3
Forgot windows password, we can use Windows Password Reset to reset our windows password.
The steps are:
Step1:Download and install Windows Password Reset
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
Reset windows password just so easy.
Trying to install new flash player,, it tells me that i need to enter root password, ive never put a password on laptop so i cant enter the password as i dont know it,, can i have new password without...
It sounds like you have an Acer with the Linux Lumpus OS installed on it.
When it ask's you for the root password the password is root. Just type root into the password box. and then install the flash player.
Regards.
Need password to install the game on my pc
Without further information, I think you will need to get the password set by whomever is the administrator of that computer. They have set a password to prevent unautorized installations.
Top Arris Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
