Question about JVC AV-32820 32" TV
Power Went out for a minute and TV needs to be reset!!! Lock Mode Problem
I don't have the remote for this TV so, I'm trying to use the menu buttons on the front of the TV to set it up. Power in the house went out for a few minutes and the TV has to be reset.
The TV has a lock mode on it and I don't know how to disable this . . . please help! Any ideas???
Thanks, Tim
  • 2 more comments
  • dolfan Feb 08, 2008
    Thank you for the response. I did turn the TV off but when I turn it on again the screen is still blue. My original remote was broken so I bought a cheap replacment that works for vol and channel changes but it doesn't do much more. The TV is still good, I have Direct TV runnning the service????
    Come on . . . $10 to tell me I need to buy another remote??? There must be an alternative solution???
  • dolfan Feb 09, 2008
    Thanks for trying . . . Which remote should I do this to? The Direct TV one or the cheap replacement one? I appreciate the help.
    Thank you . . . The Direct TV one worked . . .Thanks for your help! I appreciate it.
    Genius:
  • 3,422 Answers
Do the reset test.I give this 50/50 chance of clearing it up. Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 08, 2008
  • 5 more comments
  • Priya darshan Feb 08, 2008
    Well then iam sad to say you have to buy another original one for that so that the other functions can work and thats the only soluton..
    If u have any other problems please ask me..
    Goodluck once again and please don't forget to rate me as fixya..
    well i am trying my best to give you a solution for it but i don't think it will solve your problem cuz u will need an original one..
    Anyways wait for an hour and ill let u know if there is any solution to your problem..
  • Priya darshan Feb 09, 2008
    Hold down the menu key on the remote for 8 seconds to switch it out of that
    mode or back in again.
    Hold the "Display" and "Video Status" buttons
    on the remote simultaneously. The set will bring up a service menu.
    Press the MENU and INFORMATION buttons down together and then press 1
    then 2 then 3 while still holding the first 2 buttons down.
    Now the those two are the only solutions to solve your problem.If these don't work you have to buy a new remote..
    Right now you have a cheap replacement one so i want you to try it on that first if it doesn't work then go for the direct TV one..
Locked rca tv and don't have remote
Without its remote control you can't unlock this TV. If you have the remote control, the proceedings are:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sep 14, 2012 | RCA Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I accidentally turned on the fpa lock and don't have a remote. What now?? Any hope? I also could not get the CC up before I got locked out.
Hello
To turn out FPA lock with RCA TV, you must have its original remote control handset. If you haven't one, just buy a new one of borrow it from your friends or relatives, who own the same model of RCA TV. After unlock, you can use any other remote control. If you are using the original remote control, do the following to unlock it.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
OK.
Sep 01, 2011 | RCA TruFlat 27F520T 27" TV
My rca is locked don't have my owners manual how
Hello
If you have its original remote control, you can unlock it by one amoung the following methods. If you don't have its original remote control, try to gather it from any of your friends or relatives to get the lock out. Then you can use any other remote controls.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA Televison & Video
Tv is locked asking for a code and the color has went out, what can i do?
Hello
Just unlock it by the following methods. One amoung the will surely unlock your TV. After that you have to reset the V-Chip and other settings according to its user manual.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Ok.
Jan 05, 2011 | RCA TruFlat 27F520T 27" TV
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Preferences.
Press OK to enter the Preferences
submenu.
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
again.
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
I hope this helps and good luck!
Nov 15, 2009 | RCA TruFlat 27F520T 27" TV
Am i able to get into the menu of small orion tv without a remote
Try holding down both volume buttons on the front of the set. If the menu comes up use the the volume and channel buttons on the front of the set to navigate in the menu. I hope this helps you.
Mar 23, 2009 | Orion1934 19" TV
Television
How do you bring up the menu without the remote
Feb 24, 2008 | Televison & Video
My tv will not turn on.
First of all, forget about the remote and see if the TV functions normally using the buttons on the front of the set itself. If the TV will not power on with the power button on the set itself, then something is wrong inside the TV. If the set works fine from the front buttons but no longer responds to that remote, then the remote has either gone bad or was accidently set to a different brand. In this case, look for the original book that came with the remote (or TV if it is the original remote) and follow the instructions for setting the remote back to Zenith. Try that and post your results here.
Aug 09, 2007 | Zenith C27A24T 27" TV
The input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Jul 11, 2007 | JVC AV-27F702 27" TV
Televison & Video Logo
190 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
