Question about Whirlpool Duet GHW9150P Front Load Washer
F H error code
I have a duet front loader washing machine and have the error code F H flashing.
I tryed doing everything that cartriver suggested doing from your site and every time I do one of the things to do on his list the error code does go away but only for one wash.
I mean after evy step I do the washer works good through one wash then the code reappears.
I have done everything on the to check list and I am at wits end now.
Please, any help you can offer would be greatly appreciated.
  • Anonymous Feb 11, 2008
    I have the same problem however I think it is flashing H first then F. Is there any resolution to this?
  • oreskok Feb 11, 2008
    same problem but only after hot water was turned off when hot water tank started to leak
  • 770 Answers
If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will
be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
to fix=
If there is no water in the unit:
—Make sure that both valves at the water source(s) are turned
on all the way.
—Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
—Verify inlet valve operation.
■ If there is water in the unit:
—Verify drain pump operation.
—Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Posted on Feb 12, 2008
  • Gary Davd
    Gary Davd Feb 19, 2008
    Did you get it fixed??
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have a whirlpool duet front loader washing machine and the error code I am getting is F 28. We just had the repair guy out yesterday, can you help me with this. What is the code for?
The code is for either the MCU (Motor Control Unit ) or the CCU(Microcomputer Machine Control Unit), U probably need to rplace one of them
Good luck
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal De
