Question about Dell Inspiron 2200 Notebook
Microprocessor tool where do I get this tool?
  • Dell Master
  • 13,433 Answers
If you are trying to remove a cpu.
http://support2.jp.dell.com/docs/systems/ins8100/en/sm_en/remov106.jpg
Use a basic screwdriver to open the lock and the cpu should come of easyly if not make sure all levers are on the open position in most cases the lever would point 90* degrees strate up.
Posted on Feb 11, 2008
Hi i have a 2004 mitsubishi endevor the fuel level guage out of the blue stoped reading how do i fix it please
Do you know anything about automotive electronic's ? The fuel level sending unit inside the gas tank is an input to the PCM/ECM / ECU - engine computer , the engine computer sends this information to the instrument clusters microprocessor over serial data network .The microprocessor controls stepper motor to control the gauge . Your best bet , take it to a qualified repair shop that has the proper diagnostic testing knowledge an tools , one being a professional type scan tool that can view fuel level sensor data to an from the engine computer .
May 08, 2018 | Mitsubishi Cars & Trucks
1996 Ford Escort 1.6 Zetec, dash warning lights stay on dim even with ignition off. Light up normally when.ignition is on but no starter at-all. Plug in OBD11 tool and everything works fine
OBD11 tool and everything works fine ??? That'sjust for the engine computer ! Need a professional type scan tool to view instrument cluster data . The instrument cluster has a microprocessor inside an can set DTC'S - diagnostic trouble codes , separate from OBD2 . A bad cluster could bring down the Serial data network causing all kind of problems . Do you know what a data network is ? Your ford has SCP network .
Communications Network Information Module
Mar 27, 2017 | Ford Cars & Trucks
2006 lincoln navigator instrument cluster not working
The thing to would be to hook up a factory or up scale scan tool to see if it will communicate . Your probably unfamiliar with control module communication on automobiles ! There is a microprocessor inside the instrument cluster ! Your best bet is to take to a qualified repair shop ,there is nothing you can do . If it needs to be replaced (which is highly likely ) info in the cluster needs to be down loaded to the scan tool ,then loaded into new one .The it needs to be programmed .
When installing a new instrument cluster, it is necessary to upload the module configuration to the diagnostic tool. Following installation of the instrument cluster, download the module configuration from the diagnostic tool into the new instrument cluster. For additional information, refer to Section 418-01 . The following items are configurable:
The Expedition and Navigator instrument clusters are configurable, hybrid electronic clusters (HEC) that contain a microprocessor, gauges, indicator lamps, and internal circuitry. The instrument cluster is non-repairable with the exception of the warning indicator bulbs and the instrument cluster lens. The instrument cluster uses hardwired circuitry, and the controller area network (CAN) to transmit and receive data from the vehicles other modules. For additional information regarding the communication networks, refer to Section 418-00 .
It is very important to understand:
  • where the input originates.
  • all the information necessary in order for a feature to operate.
  • which module(s) receive(s) the input or command message.
  • does the module which received the input control the output of the feature, or does it output a message over the communication network to another module.
  • which module controls the output of the feature.
Jul 27, 2016 | Lincoln Cars & Trucks
What does fault #6 mean
It depends on the type of machine and comtroller you are asking about. If it is a VSD Fault #6 it means there is a problem with the microprocessor or the control board.
Mar 03, 2016 | Ingersoll Rand Air Tools & Compressors
Error eepr problem
If it's Fluke DMM then - corrupt eprom in microprocessor - replace microprocessor or main board
next time put make and model of the unit - it makes it easier
Aug 26, 2013 | Measuring Tools & Sensors
Display Panel Microprocessor No.
is a programed microprocessor (microcontroler) , only the jvc has correct version.
Jan 17, 2010 | JVC THD-50 System
Sanyo 32'' sound and no picture ? get a blue screen no channel id markers
Try unplugging it for about 5-10 minutes and see if that clears up the problem. Why? Because they have microprocessors in 'em (computer chips) and just as like with any other operating system, they can hang up or crash. This isn't an uncommon problem with today's TV sets. Unplugging it for awhile resets the microprocessor (in other words, it causes it to re-boot when you plugit in again).
There are 3 step to repair blue screen error
If you got blue screen error then there is a 94% chance that your computer has registry problems. To repair blue screen error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair blue screen error.
Here are the url of Perfect Optimizer: http://www.fixerror365.com/tidpp-blue_screen_error-zz0005
Aug 16, 2009 | Sanyo Televison & Video
Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Sep 20, 2008 | Denon AVR-1508 Receiver
Mitsubishi VS50605
Can I ask you why you think the microprocessors bad? I have never in all of my years of repairing Mitsubishi TV sets ever had a bad microprocessor. Did a tech tell you this? Let me know what the symptoms are.
Jun 12, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Dell Inspiron 2200 Notebook Logo
115 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
