Question about Saeco Caffe Charisma Espresso Machine
Saeco Cafe Charisma
Can I increase the brew temperature on my Saeco Cafe Charisma?
    New Friend:
I have been told the proper temp should be between 195 and 200.
Posted on Feb 27, 2013
  • 46 Answers
No! the max temp is pre set to about 90oC to 95oC on the p.c. board. any higher temp will cause the the coffee beans/grounds to burn, thus BAD TASTING coffee , according to most experts (barrista)
Posted on Feb 09, 2008
Clogged, not much coffee coming out
That is a common problem.
especially if it has not been cleaned
most likely it is the metal screen filter in the brew group
clean the brew group
Jan 15, 2014 | Saeco Caffe Charisma Espresso Machine
Saeco Incanto "grinder blocked"
provide in detail about your problem ..........
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
Temperature control on Saeco magic deluxe
No it cannot. I am not sure why you would want the water hotter. It is designed to be at the perect temperature for passing through the brew group for coffee brewing, its kind of a simple science.
If your machine has been producing less hot coffee gradually, that marks an issue. Try descaling the boiler per the manufacturer's inscrutions even if the warning light isnt on. The other option is that the thermal fuse mounted to the boiler is bad and turns off the boiler prematurely, those cost about $15 and are simple to replace. Lastly, the boiler heating element may be 'burnt out' new boiler is $120+
Aug 15, 2009 | Saeco Magic De Luxe Espresso Machine
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
My Saeco Caffe Charisma leaks water from the frother as it brews.
Hi
Mi=ore than likely you have something under the needle seat that is holding the needle open. Usually it is scale. Try doing a descale manually. Mix the solution and put it in the water tank. Turn machine on and then immediately open the water knob. Run about 8 oz. and turn machine off. Let stand for 10 to 15 minutes. Then repeat an 8 oz. run and turn off. Again let stand. Do this until the tank is gone. Then rinse, and test. If that does not do it, you will have to remove the top and remove the cover on the manifold that holds the needle and clean manually.
Jun 16, 2009 | Saeco Caffe Charisma Espresso Machine
Saeco Vienna: water does not go through to the main unit
on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
May 20, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
218 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
