Televison & Video Logo
Posted on Feb 08, 2008
Dvd tv help please i have a new tv as below but the dvd player only playes in black and white all other cchanels are colour l but as soon as you switch to dvd it goes to black and white thanks
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Feb 10, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
0
Helped
3762
Points
15
You need to check if the dvd is in svhs mode on the dvd channel as that is normaly the problem or could be a scart lead problem try another one
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Magnovox dv220 mw9 plays in black and white only
Hello
The output signal's colour system to this player is NTSC. Just look whether your TV is NTSC system compactable. Check whether the disc is recorded in any other colour system, like PAL or SECAM. These are the reasons for absence of colour to the picture. Check whether the colour control of the TV is at minimum.
When I play a DVD, it is in black and White. When I play the tv it is in colour. Can't get the DVD to play in colour!
You have one of several possible problems, ranging from best case scenario to worst case scenario:
A DVD video that is supposed to be black and white - try a different disc.
Some setting on the DVD player is set to monotone - check manufacturer's instructions
A bad set of cables connecting the dvd player to the tv - test a known good set of cables
A bad output on the DVD player - test DVD player with a different TV.
A bad input on the TV - try another input if possible, test TV with a known working video input.
2helpful
2answers
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
2helpful
2answers
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
2answers
DVD player will only play in black and white
are you using a/v inputs or composite inputs .
2helpful
16helpful
7answers
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
