Then it is not the charger. Are there any lights showing on the laptop when you plug it in? Try wiggling the power cord attachment and see if you get any kind of connection. Could be the power jack on the motherboard quite common on all laptops. Could be bad ram module, cpu or motherboard. Need more information....
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery. If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
You can't force the battery with a higher charge to work without damaging the computer. If the battery is a direct replacement it should work. If your original charger is not capable of charging the battery you can consider a charger replacement but I suspect the original charger you where using was bad to begin with if that is the case. You can try locating a replacement charger but you need to make sure it is rated for computer so you don't damage the power system.
should find out why the original charger stopped working in the first place... was it a faulty mother board really.
anyway if the ratings on the charger you bought are for that laptop indeed, then it should power up the laptop minus the battery. ofcourse if you put in charger minus battery, dont expect it to show the charging led..just try to power it on
Regards
if you just plugged in a new charger you should be able to power it on even if your battery is dead. laptops can be powered on even without its batteries as long as the chargers are connected to the laptop.
i think you have to bring your laptop for servicing.
