Vga card i have all in one panasonic cf-82 pc with 2 monitors one monitor operating the other not can you help me solve this problem as i dont have any drivers for my pc . thanks
  • prestige Feb 09, 2008
    thanks alot i will let you know if it works
    Novelist:
    Scholar:
  • 108 Answers
I am helping...(soft sounds of prayer and chanting)...but I doubt that will work. First you had to have had a driver if you have one working. Secondly this sounds like it might be ATI or Raedon. Do those names ring a bell. If so....go to control panel. Select display and search around. You have to set it to use both monitors. Try this first. If not comment and I will give you steps 2-10. Tango
Posted on Feb 09, 2008
Screen gone white
The screen cable could be damaged around hinge area.
Try to connect an external screen (PC monitor or TV screen) via VGA port to see if you get any image.
Jul 06, 2014 | Panasonic Toughbook CF-30 (CF-30K3PAX2M)...
Never light up on screen when turn it on
On any Panasonic Toughbook, if the LCD does not "Light-Up", I would try the following:
Step 1: Make sure the Toughbook is Powered Off.
Step 2: Hook-up and external LCD Monitor to the VGA Port.
(On the CF51 with the ports facing you, the VGA Port is the third connector "color blue" from the right hand side).
Step 3: Power On the external LCD Monitor.
Step 4: Power on the Toughbook.
If the external monitor works then purchase a second hand external monitor. A used 17" LCD monitor should cost $20 or less and the VGA cable (used) should cost $5 or less.
This also means that your LCD may be burnt out. If this was a CF53 or even a CF52 then it is worthwhile to repair. The CF51 in my opinion is too old but at least you can continue to use it with an external monitor hooked-up.
That is it. Good Luck and Best Regards from:
Richard Montreal Based Panasonic Canada Authized ToughBook Dealer since 1989
Feb 18, 2014 | Panasonic Toughbook CF-51 Notebook
External display video monitor
On Page 10 of the Operating Instruction Manual
for the Panasonic Toughbook CF29, it shows
the "External Display Port" or VGA Connector
located on the back side with the cover closed.
This port is located approximately in the center
of the back side, just to the right of the
port replicator port and may be colored "BLUE".
The manual can be found here:
ftp://ftp.panasonic.com/computer/om/cf-29htlgzbm_en_om.pdf
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 02, 2014 | Panasonic Toughbook CF-29 Notebook
I have a cf-29 and my screen changed to black with weird lines going top to bottom. i was thinking it might be the video card any help would be great.
With any model of Panasonic Toughbook, the proper diagnostics would be to plugin an external monitor when the Toughbook in powered off, then turn on the power on the external monitor first and then finally turn on the Toughbook. If the problem is the video card then no image will display on the external monitor.
If you get an image on the external monitor, then the problems is the internal LCD screen.
The external monitor connects on the back or rear side of the CF29 in the external monitor port or VGA connector. This connector is typically "blue" in connector and has 15 pins (3 rows of 5 pins).
Good Luck and Regards from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Sep 08, 2012 | Panasonic Toughbook CF-29 Notebook
How to reset password?
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 05, 2012 | Panasonic Toughbook CF-51 Notebook
No display
Tell me if you can see anything on the monitor while the pc is booting/starting.Is your monitor connected correctly ?Is your monitor operating well with other PC?
This motherboard you have has an onboard VGA card. Check if you have a PCIex VGA card connected on the motheroard.
In case you have one then deactivate the onboard one through the bios and connect your monitor to the PCIex one.If you dont have an external PCIex card thenGive me more details if you want me to help you.
Sep 04, 2011 | ASUS P5KPL-AM SE Motherboard
Dont work the video card on external monitor
Once you have to monitor plugged in, look for a key in the top number bar on your keyboard with a monitor symbol on it. you may have to hold FN then strike that key to access it.
May 03, 2011 | Panasonic Toughbook W8 (CF-W8EWDZZ2M) PC...
My computer turns on but the screen remains black. What should I do?
The problem can be solved by these steps
1) Check the Video connector properly connected to PC
2) Monitor power supply cable fault
3) The VGA card is not working properly
4) The screen resolution is set to higher than the monitor supported resolution limit
The Best way to solve it replace monitor and see it is working properly
In case the monitor still stay blank you should check the VGA card
Try to start cmos setup and see whether the monitor still remains blank then it's VGA problem
Feb 07, 2011 | Compaq Computers & Internet
S-video input from Panasonic MD830 S-VHS to Gateway 2100 monitor causes monitor to intermittently project signal or turn off. Will a S-video to VGA converter solve this problem or is there a problem witth...
It seems the the monitor is not supporting the resolution you have selected in display settings of operating system. therefore please minimize the resolution of display then check your monitor. hopefully it will work
Apr 08, 2009 | Gateway E-2100-V2 (E2100V2-D) PC Desktop
I have an CF48 and a CF25 Personal Computer. I would like to know what size RAM and HD and Processing speed these laptops are issue with from the factory.
I looked up info i dont know if this the right computer you ment but
Panasonic Toughbook CF-48 CF-48X4HLUDM
Processor: Pentium 4 1.8 ghz Display Size: 14 inch Hard Drive: 20 Gig Memory: 256 meg Optical Drive: CDRW Drive (Burner) Floppy Drive: Built in PCMCIA Slots: 2 PCMCIA Slots Sound and Speakers: Built in speakers and sound Pointing Device: Track Pad Ports: 2 USB, 1 Parallel, 1 Serial, 1 VGA Modem: Built in 56k Ethernet Network Card: Built in 10/100 Operating System: Windows XP Professional AC Adapter: yes Battery: (not warranted) yes Warranty: Lifetime Limited Warranty
Dec 16, 2008 | Panasonic Computers & Internet
Computers & Internet Logo
103 people viewed this question
Alun Cox
David Payne
David Payne
