Question about Electrolux Guardian Bagged Canister Vacuum
Belt came off
I put the belt back on but am not able to get the power nozzle back together
Wasn't able to fix the problem will have to take it to the repairmen
Posted on Feb 09, 2008
How to get the vacuum apart to change the belt
Turn power nozzle bottom up.
Remove the 5 screws.
Insert tip of a standard screwdriver into each square hole on either side of the wheels and twist to release the tabs.
Holding the power nozzle together, turn it over.
Lift the back of the cover up, then remove it.
Remove the screws at the ends of the brush.
Lift out brush.
Remove belt and replace with new belt.
Place brush back into slots and replace screws.
Check belt to make sure it's settled correctly and check tautness. It should have some give, but not much.
Replace cover by inserting front lip into the slot at the front of the base. Carefully manipulate into place, ensuring the latches click into place.
Turn PN bottom up.
Replace screws.
Feb 25, 2011 | Electrolux Epic 3500 Vacuum
The motor on my carpet tool (beater brush) stopped running yesterday. The main vacuum still works, but the switch for the carpet tool just clicks and doesn't turn it on.
Knowing the model would help.
Possible problems:
Broken or disconnected wire in hose, connections, power nozzle.
Hose needs replaced. Check all connections for discoloration and cracked supports. Have power nozzle checked at a vacuum shop. Depending on the model, take it to an authorized Aerus Electrolux store for this.
Bad power nozzle motor Needs replaced.
Bad switch. Take the whole machine in for thorough check and repair..
Jan 25, 2011 | Electrolux Vacuums
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Thank you very much,
Chris J.
GoVacuum
Apr 07, 2010 | Vacuums
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Chris J.
GoVacuum
Apr 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I need instrution on how to change the belt on my kirby 4 power
you have to be more spicific on the model but: if you take off the front nozzle by loosen the nozzle lock, make sure the name kirby is horizontal, loosen the latches at the back of the nozzle un hook the rugplate located at the bottom of the nozzle...take out the brush..... slip out the old belt...in with the new one. put back the rugplate, lock the latches. NOW turn the nozzleknob anticlockwise until it stops at where the 2 arrows align, put the nozzle back on the main machine and lock the nozzle lock underneath the light.then turn the knob ALL the way clockwise until arrows allign again....switch on machine ..make sure green lihgt on nozzle comes on....
May 17, 2009 | Kirby G4 Bagged Upright Vacuum
Cant rember how to replace the belt on the power head
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off of the Kirby's driveshaft but on the "hook" inside the power nozzle) 2)Remove the power head from the front of the machine. Now that it is off the Kirby, you can turn the square belt lifter until the green arrows line up. (Belt on, which means on the driveshaft on the front of the Kirby when the power nozzle is on the Kirby which makes the brushes spin. Now that the power nozzle is off of the Kirby, the belt isn't actually resting on anything but the green arrows will still point to belt ON ) This removes the belt from the "hook" so that it can be slipped off the brush roll. 3)Turn the power nozzle upside down and release the two clips that hold the metal baseplate on and remove the baseplate. 4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. 5)Look at the ends of the brushroll. The brushroll has three height settings..you should see notches AND NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong. Also, one end cap of the brushroll is larger than the other and will only fit onto the larger notch in the power nozzle. 6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage. 7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place. 8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
How do I replace the belt on my Kirby sweeper---a G4? Thanks!
Hope this was helpful :) and thank you for using Fixya!!!
May 16, 2009 | Kirby G4 Bagged Upright Vacuum
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Electrolux Guardian Bagged Canister Vacuum Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
