Question about Toshiba 57H82 57" Rear Projection Television
Red green and blue rainbow shape
I have a toshiba 57h82 and my tv turned really blue now its white with the colors shaped like a rainbow i tryed to touch focus but it comes back as error what should i do plus i have fuzzy pic before that with white lines flickering on the screen is this tv worth fixing
  • mrlilsnoop0 Jun 19, 2008
    hello, my tv was working fine and out of nowhere the picture got distorted, but in this case the red light seem to be the badone, it seems like if the bottom line got in to like a rainbow shape in towards the center of the screen, we tried the touch focus button a couple of times but no improbement, i also tried to start allayning te cross marks in the convergence opption but it didn't helped mush. I hope this tv can be saved. Either wat Thank you
  • FEYA May 11, 2010
    WHAT DID YOU DO TO FIX THE PROLEM PLEASE E- MAILBACK AT WWW. JOBS42DAY@AOL.COM
Repair the convergence circuit
Posted on Feb 09, 2008
There's no YELLOW PORT on the Element TV - Where does the yellow from the DVD player ... red/white/yellow plug go?
Just match the size and shape of the plug to the matching socket shape on the TV.
Apr 03, 2015 | Televison & Video
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82
your convergence amp ic's./if you want to cheat/align the other two colors and manualy move the green yoke rings on the green picture tube neck so the green cross aligns with the red and blue.,they shuold form white when all three are aligned,on top of each other.
Sep 13, 2007 | Toshiba 57H82 57" Rear Projection...
Hourglass shaped red
I need to see a picture of the TV set. send a photo to techman32k@yahoo.com
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
Toshiba 57H82 57" Rear Projection Television Logo
223 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
