Question about Kodak EASYSHARE Plus Series 3 Thermal Photo Printer
Cutting perforations at top and bottom of prints
My printer is making perforations in top and bottom of my prints also leaving a white thin strip on one side.
    Problem Solver:
  • 16 Answers
The paper is perforated prior to printing...
You have answered questions regarding people who have photo printers. The questions asked are based on thermal transfer image printers, not bubble jet as your answers seem to be based on. FYI if people are having issues with their thermal printers, particularly with pictures printing, "Printing" partial pages, how in the world could you deduce that there is a driver issue? You've been more harmful than helpful. If for some reason there is "No" printing being done, then sure 25% of the problem could be drivers or firmware issues. However if it all of a sudden happens, then we have to think of it like a chain on a bicycle suddenly
breaking. Which in this case has a percentage of 50% or greater being the problem.
The lucky ones, (those w/ mechanical aptitude) can simply open the printer and make the screw adjustment(don't get me wrong it's time consuming and tedious) but the unlucky ones will find a cracked gear assembly which depending on the seriousness may be able to be repaired with "Model Glue". The recommended action is to follow your warranty, should
you not have one, guess what, these models are no longer manufactured for this exact reason. Which is why Kodak changed the color to Black on the new ones. So remember, if you buy it on sale... You now have full experience as to why the item was on sale in the first place, same goes with Manufacturer coupons as well!!!! If you want an item to last you don't buy it on sale, that old wives tale of 'Overstocked Item' is a gimmick
and remember to follow the item you purchased at full price. If all of a sudden the items price drops to half price, contact the manufacture to find out why, you may have a hidden problem, and if you contact them inside your warranty range you stand a good chance of receiving a voucher for a replacement model to keep you from getting to the point you are in currently. Good luck, and remember if it's on sale, you should reconsider how long you are going to long you need the product before you buy
it!!! Computer, Copier, Printer Technician 35 years..
Posted on Jul 07, 2008
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
White line across photo
clean ur printer head. and check that if any air ur ink box
Jul 21, 2009 | Dell 540 Photo Thermal Printer
Prints faint and cuts of the top and bottom of some lines
The ink in the cartridges has dried up. Replace them.
Feb 01, 2009 | HP DeskJet 950c InkJet Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
Vertical black line on all print outs
1) Check the cartridge. Look at the egg color drum and see if there is any built up toner. If there is then wipe off with soft cloth and reinstall.
2) Does this happen when coping from the flat bed and the doc feeder at the top?
If it it's only from the top then there is a glass lense that might have white out on it.
This is common when using white out and not letting it dry long enough.
To get to the lense it my be tricky but if the top of the feeder open a little from the top pop it open and
the glass is a thin 1/4 strip. Wipe it clean then try again. Hope this helps. Boats
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Prints extra strip in between
try to reset the settings in the printer panel inside the printer setup menu. try to choose the initialize all. then observe your printer operation.
Jan 10, 2008 | Epson Stylus Pro 9600 InkJet Printer
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
Kodak EASYSHARE Plus Series 3 Thermal Photo Printer Logo
47 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
