Hi Yes you can try clean.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
SOURCE: I have put new inks
Please forgive me for suggesting the most simple of solutions, but.....many times, people forget to remove the tape that covers the ink ports on a new cartridge. If you have already done that, forgive me for thinking in such a simple manner.
SOURCE: My Epson Stylus C88+ printer won't print
Sounds like there's a problem with the print head. I'd recommend doing a nozzle check, if any colours are missing from the print out then try some head cleans. You can find the nozzle check and head clean options in the maintenance/utility tab of your printer driver.
SOURCE: replace ink cartridge
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Have a nice day and do not forget to rate please...!
SOURCE: Cleaning ink Head Printer/Scanner for Epson Stylus
Many people use the following to clean the nozzles if the software utility doesn't work.
http://www.hawksphotovideo.co.uk/paper_accessories/Permajet_Clever_Clogs_Print_Head_Cleaning_Kit_2x30ml_APJ55820
Zahc
