Question about Linksys Wireless-N WRT150N Router
Wrt 150n Wireless signal from router to laptop is very weak. I bought this router for it's extra strength and distance. What should I do?
  • 12,061 Answers
OK maybe get an external antenna in any event place the Unit/Antenna up as high as possible... also ensure ya aren't near any large metal objects/power wire junctions etc, but generally an external antenna will Boost ya signal, also even just moving "it" somewhere else can make a big improvement... In some wifi routers ya can increase and decrease ya output, ya may wanna check ya manual to see if yours is one of those? Ya may also want to try changing "Channels" on the Router too.. this also has been known to help. Good Luck :)
Posted on Feb 08, 2008
I have a linksys wrt 150n router. i've connected my imac wirelessly, but cannot get my pc-laptop to connect. what am i doing wrong? yes, it is secured with a password.
hi parkerjunkma,
be sure you detected the wrt..then the SSID and Security Encryption should be matched..the SSID will definitely detected so the Password should be entered.
mastergani
Dec 28, 2010 | Linksys Wireless-N WRT150N Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
I have the DIR-655. Poor coverage/Signal strength
What kind of construction surrounds your router? Weak signal indicates walls reducing signal strength. Try a repeater in weak areas.
Dec 30, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Dec 26, 2009 | Acer Aspire One PC Notebook
Low signal strength, fluctuations in signal strength
1. probably the distance between the router and the laptop 2. Interception from other devices like cordless phones , cell phones, micro wave ovens 3. Upgrade the firmware of the router
Hope this helps
Thanks
Ranjit
Nov 04, 2009 | Buffalo Technology WHR-G54S Wireless...
Weak wireless signal - WRT160N is a piece of trash
We found Linksys wifi units to be unusable a few years ago. I had a stack of them that the wifi had died or was unstable or short ranged and none of these were more than a year old. They have had quality problems for about 5 years. Tech support is handled overseas and consists of them reading off of cheat cards. If you get through to a tech you will find them not to understand any technical jargon and once not even normal non technical english.
Our "fix" (and what I'd reccomend if you want to avoidl headaches) was to yank out all remaining Linksys units and replace with a different brand. We didn't see any difference with the models, they all failed in some way. I don't know what happened to the company but they used to have a very good product. They don't have that now.
Sep 12, 2009 | Linksys WRT160N Wireless Router
Laptop keeps disconecting from belkin54g dsl network (home)
Wireless connections are best when distances are short and there are no brick or thick walls interfering with the signal between the router and your laptop. Try the following test:
Start using the laptop from an open location that is close to the router. Monitor the signal strength as you walk away from the router. Go into other rooms, go upstairs, downstairs, etc, and you will most likely notice differences in signal strength depending on where you are, or how far you move. Of course, you will suffer frequent disconnections when the signal is at its weakest point, no matter what equipment you use, be it new or used.
Try locating the router in a way that your signal strength is strongest, without affecting the other computers. It's a trial and error thing.
One last thing you could do is to go to your wireless adaptor configuration settings and set the Roaming capability to agressive, and set the connectivity to distance, for higher performance.
Aug 19, 2009 | HP Pavilion dv4000 Notebook
CAT 5E DISTANCE
Considering what you started with, it should be slow :-)
If this were my installation I would run HUGESNET>Router>BRIDGE>BRIDGE>ROUTER/AP>PC
The first router is the 150N. The Bridges are two Wireless Access points in bridge mode designed for distance. A nice unit for this application is a TP-Link WA-601G with antennas (ANT2408) found here:
http://www.tplink.com/products/wlan.asp
It will cost you an extra $100-150 depending on antenna, but it should get you good results, considering the SAT is probably 300 down and 128 up :-)
Carl
Apr 05, 2009 | Computers & Internet
I have a WRT 150N wireless router. it is not putting out a network but i can connect to the internet with one of the lan line ports
Connect to the router via the admin screen and select the wireless tab. Check to see if wireless is set to disable or to a setting that is not compatable with your PC/laptop wireless card.
Hope that helps and thanks for using FixYa
Mar 07, 2009 | Linksys Wireless-N WRT150N Router
Connect another laptop using Vista operation system to my wireless network
thank u for the clarification..if it says "low signal strength" then u will have to reduce the distance between the laptop and the wireless router..also please ensure there are no big objects,walls etc between the two..u can get better signal strength by doing these..also other nearby wireless networks and cordless phones can hamper with signal..hope it helps!regards!
Nov 02, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Linksys Wireless-N WRT150N Router Logo
134 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
