Question about Apple iPod nano
White Ipod Nano 1st generation
My ipod is stuck on the hold option. No matter how many times I toggle the hold button, I cannot unlock the wheel. Any suggestions? I have tried restoring it and all of the typical suggestions. None of them will unlock the wheel.
  • 51 Answers
Hold Down menu and the centre button until the apple logo appears.
I dont know otherwise.
Hope That Helps
Regards,
Sophie x
Posted on Feb 14, 2008
Apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Apr 03, 2008 | Apple iPod nano
I connect Ipod to computer it will not sync
Try resetting the iPod, this usually works.
As follows:
http://www.pchelpforanyone.blogspot.com/
Mar 10, 2008 | Apple iPod nano
Ipod Nano 1st gen - locked
The internal mechanism might have worn out.
Feb 08, 2008 | Apple iPod nano
Problem unlocking
need help lock 8gb ipod need big help now
Dec 05, 2007 | Apple iPod MA446LL/A MP3 Player
Apple Ipod Video
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Nov 29, 2007 | Apple iPod MA446LL/A MP3 Player
30 GB Ipod Video Problem - Its locked
  • iPod classic
  • iPod nano
  • iPod mini
Nov 27, 2007 | Apple iPod MA446LL/A MP3 Player
When turning on my iPod keeps saying to go to the Apple web site for support
  • iPod classic
  • iPod nano
  • iPod mini
Nov 26, 2007 | Apple iPod MA446LL/A MP3 Player
I FORGOT MY CODE
  • iPod classic
  • iPod nano
  • iPod mini
Oct 23, 2007 | Apple iPod MP3 Player
Sync problem
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 07, 2007 | Apple iPod nano
Ipod Nano Second Generation
Aug 24, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
