Question about Hitachi CP-X250 Multimedia Projector
Projector Hitachi LCD projector which is mounted on the ceiling How can I clean the filter?
Get a ladder.
Posted on Oct 29, 2008
Optima Optima hd81 projector mounted on ceiling now picture is upside down
There is an option in the setup menus to re-orientate the picture, to flip it either vertically, horizontally or both to correct for the various installation options. You should be able to correct it quite easily :o)
Mar 29, 2014 | Hitachi PJTX100 Multimedia Projector
Hitachi cp-x300 will not go into advanced mode
I don't know that model but normally mirrored (ceiling) settings are in the basic menu. Some of the hitachi models won't go to Advanced mode or some of the image settings unless there is a signal that they are adjusting as you end up with settings for the RGB input and separate settings for composite (video via phono)
Dec 11, 2012 | Hitachi CP-X300 LCD Projector
Projector is mounted on ceiling mount. Projector
try it without the ups unit, just in case the ups unit is dodgy
Jun 09, 2011 | ViewSonic PJ506D DLP Projector
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Oct 02, 2008 | Hitachi CP-X275 Multimedia Projector
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Upside down picture
Use the mirror function from the menu as per the picture below choose V:INVERT. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Hitachi EDPJ32 480p Enhanced Definition...
Hitachi CP-X250 Multimedia Projector Logo
169 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
