Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
No video, no sound, power button light on constant, front panel light flashing
My tv started stopped working the other day, there is no video or sound, the power button on the front stays lit all the time but the light that is above the other buttons on the front(sound, channel up/down) blinks very slowly on and off. It does this when I plug the power cord back into the wall. I've left the tv unplugged overnight but the issue is still the same. Pushing the buttons on the tv has no effect, I've also taken the batteries out of the remote in case that was causing some type of issue. The light stays on for about 15 secs, then off for about 15 sec, ect. I've counted how many times it cycles on and off like this, one time it did this 8 times but it seems to cycle the light 2 times every other time I've powered the tv on. I've taken the lamp out and reseated it, also the lamp looks ok as far as I can tell. When the tv is initially plugged back into the wall it does make a sound like the tv is getting power but the fan never comes on.
Thanks
Paul
  • paulschauer Feb 13, 2008
    I had an RCA tech take a look at the tv, he diagnosed it as the light engine which would have cost $1300. The tv is now headed for a electronics recycler.
  • 149 Answers
Have a good tech diagnose this and there is a commom problem with this set in the power supply but is not nessesary to junk the set some places rebuilt light engine if thats the case
Posted on Apr 02, 2008
TV will not turn on, only flashes green status light on front constantly, any suggested fixes?
A button may be stuck down, this is what happened to my TV when a button was stuck.
Dec 08, 2015 | Mitsubishi LT55164 55 in LCD TV
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
My TV (Sylvania 6842THG) wont power on
Sounds like one of the video cards inside the TV stop working or the plasma panel has stop working.
Nov 27, 2012 | Televison & Video
No picture or sound
Hello Sirs, you need to publish the TV brand name & the model number.
Jan 13, 2018 | Toshiba 32BV700B 32 in. LCD HDTV
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Power Light on constantly ....no pic or sound....nothing.
Yep, your mainboard is damaged.
Replace it and your tv will work again
Jun 02, 2009 | Westinghouse SK-32H240S Television
Constantly flashing "Not available"
I have the same TV and had the same problem. It's due to a failure in the front-panel buttons, which are very sensitive. Mine got so sensitive that they were registering presses all the time, even when nothing was near them.
Since I never used the front-panel buttons, I solved the problem by opening up the TV and disconnecting the front panel from the rest of the TV electronics. This was somewhat difficult to accomplish due to the fair bit of TV disassembly I had to do to get to that connector. After I put the TV back together, the "NOT AVAILABLE" problem was solved, but somehow I had damaged something else--the tuner, composite, and S-Video inputs lost their color and now only show up black-and-white. (Luckily, I only use the component video inputs, which were unaffected.)
Aug 05, 2008 | Samsung TXN2771HF 27" TV
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
196 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
