Question about Kicker ZR600 Car Audio Amplifier
Kicker car amp overheating
The fan comes on but does not function after being on and warming up.
  • 631 Answers
Disconnect the speaker wires and the RCA cables from the amp. If it still heats up, the amp has an internal fault. If it doesn't, you need to check the wiring for shorts and you need to make sure the impedance is what it should be (no less than 2 ohms per channel).
Posted on Feb 09, 2008
FLUTTERING TEMP GAUGE I8N 2003 SATURN VUE
Well son, there are MANY reasons that might cause "fluttering" in your gauge. Mine started doing that, then I started getting a warning LIGHT for overheating. My solution for that was a fault in my fan. There are 2 speeds on my VUE'S electric fan. The one that required attention was speed/high (the speed/low was working). If your getting an intermittent short, watch both the temperature and fuel gauges to make sure it's not a real (both will do the "fluttering at the same time if it's faulty short) overheating problem. If you have an OCD-2 reader, plug it in under the driver's dashboard and go to function "live" read the engine temperature. If that's normal it will be between 120F-200F.
Faults may be relays in the under-hood fuse panel (there either good or bad, you can't see anything like other fuses) and there are the 30 amp or 10 amp fuses inside the same fuse block for that electric fan.. I've found that if I open the hood and start your car, after it warms up, there are tree things that could happen.
1: the low fan starts up, then start your A/C, the high fan speed comes on (normal, check your temp gauge).
2: After you warm it up, the low speed fan starts up, but with the A/C on, the high speed fan isn't coming on (bad high speed fuse or relay).
3: after warm up, the low speed fan doesn't come on, but starting the A/C the low speed fan comes on (bad sensor I think).
I've had a ghost in my VUE since I bought it, gone through 3 computers, CVT sensors, key won't turn without destroying the key. One time, I used the horn to get some deer off the road and the damned thing wouldn't shut off. While I was under the hood trying to get it to turn off, TWO cops stopped, they shined their flashlights on the fuse block and one on the diagram for me to pull the right fuse. I took it out, plugged it back in and it worked again! The shop didn't find a thing wrong with it, but the thing works still.s
Aug 13, 2014 | 2003 Saturn VUE
1990 Buick LaSabre, limited V-6 3.8 overheating, replaced fan, & thermostat & cooling temp sensor. runs rich and fan won't come on?
on that motor they are prone to blowen head gaskets you need to do pressure check of the cooling system
Jul 26, 2012 | 2000 Buick LeSabre
My protection light keeps turning on.
i'm almost positive that your amp is overheating. i would either buy another one or bring it in to the geek squad. but i'm 99.9% sure it's overheating
Apr 28, 2010 | Kicker ZX10001 Car Audio Amplifier
What kind of amp do i need for 2 kicker ds6930 140 watts peak and 2 ks6930 6x9 watts peak 150 and 3 Kicker KS350 3-1/2 40 watts each peak
600 Watt to 1000 Watt 4 CHANNEL AMP for the four 6X9's and a less powerfull 4 Channel amp thats at least 200Watts to 400Watts peak for the 3 3-1/2 kicker speakers. Because if you try to connect the 3 3-1/2 speakers to only 1 4 channel amp that the 6X9 speakers are on you risk of overheating the amp and blowing the speakers too!!!
Apr 05, 2010 | Kenwood KFC-6982ie Car Mid-Range Speaker
The protection light come on
if your amp gets to hott the protection light comes on make sure you have fans on the amp
Mar 29, 2009 | Kicker KX250.2 2 Channel Car Amplifier...
Kicker ZX300.1 shuts off after long play at high volume
It's probably overheating and the thermal protection circuit is shutting the amp down.
If it has a fan, the fan may be defective. If I'm not mistaken, the fan only runs at high temperatures so if you check it, you need to do so when the bottom of the amp is almost too hot to touch.
If the fan is working properly, you may be driving too low of an ohm load.
If it's neither of those, get the amp up off of the mounting surface and use an external fan to move air across the bottom surface of the amp.
Oct 11, 2008 | Car Audio & Video
Kicker SX900.2 keeps overheating. Please help!!! = )
sorry your problem is the soft you moust go to the service center
Aug 16, 2007 | Kicker ZR600 Car Audio Amplifier
Kicker ZR600 Car Audio Amplifier Logo
137 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
