Question about Sony KV-20S20 20" TV
Sony Trinitron KV-20S20
TV is 12 years old. Just developed horizontal white bands with black diagonal strips across the screen. The bands do not fill the entire screen – probably 40%. This problem appears after a couple of minutes or can be intermittant or just turn to snow. Also, loud static noise. Can this be easily fixed or is it shot?
  • vermonter Feb 12, 2008
    Did not address the actual problem. What causes this?
    This can't be the only TV that's ever had this problem.
    Thanks. That answers my question and confirms my hunch that
    it is not worth putting good money after bad!
  • 579 Answers
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board by sending it to Module Exchange at 972-298-1212, or PTS Electronics 800-844-7871 ptscorp.com.
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Posted on Feb 08, 2008
  • Greg Collins Feb 12, 2008
    What you are seeing are called "hum bars". The scan rate of TV's
    is 60hz, same as the 120V line frequency. There are many
    capacitors in a TV that filter the power going into the circuitry to
    keep this line frequency out. As the capacitors dry out with age
    they start to leak and let in the interference and you get these hum
    bars. It is difficult if not impossible to track down which one
    of them is the problem. One of the main reasons not to fool with
    fixing old TVs.
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Sony Trinitron 29inch Color TV
The 2 blinks are an indication of over-current. This is usually because of a shorted component. The most common is the horizontal output transistor. This will be a 3-legged part attached to a heat sink close to the flyback transformer (part with red wire coming out the top). This transistor will be marked C4856 or something similar. Update this with the exact marking and I'll provide you with the full part number and approximate cost.
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony 20" Mod. 20S20 Trinitron tv
Best buy is to get a converter box. this model was built long before DTV (1996).
Jul 05, 2008 | Sony KV-20S20 20" TV
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Top half of screen is dead
HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
191 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
