FixYa.com
Tags:
NEC VT47 Multimedia Projector
NEC VT47 Blink Sequence but not comming up. (by 2 users)
posted by CMS Installs on Feb 08, 2008
My NEC VT47 Projector stopped working and I now get a blink sequence at power up. I thought the bulb might have gone bad but it was not the bulb. Can you help me to troubleshoot this problem or direct me.
The Blink sequence after power on is:
1 Unit blinks normal
2 Fan Stops
3 Power goes off
4 Beeps 3x
5 Power and Status blinks 6x
6 Power blinks 2x
7 Steps (5&6) happen 4x
Thanks for your help,
Karl
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dwnbct, posted on Apr 01, 2008
The status light is blinking red every .5 second at .5 second intervals for 6 cycles. The power light is solid orange. Per NEC manual, it says to wait a minute and restart. It just continues the same error condition. I replaced the lamp, same problem occurs. I tried a known good lamp from another projector, same problem occurs. Any ideas?
I tried your solution of: For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out.
Same blinking status light. I replaced the bulb and tried again, same blinking status light. I checked the filter, etc. This projector has not run for 2100 hours, so the bulb should be okay. Please help!
Solution #1
posted on Feb 27, 2008
Not Rated (0)
Gigatech
Rank:Guru Guru
Rating: 87%, 317 votes
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
movie mate 30 brojecting blue...
Hi; My name is robert and i... Answer This...
HI to all my heros
Please am using a Toshiba... Answer This...
NEC VT47 Cropped image on left...
This projector seems to work... Answer This...
nec password
i lost my password and now my... Answer This...
Unable to reset VT47 after lamp...
The lamp exceeded the hours of... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
