Nokia N76 Cellular Phone
Problem for Nokia N76 Cellular Phone
Blank white screen
By ugglou on Feb 08, 2008
my phone is only showing a blank white screen when switched on
Same Problem
May 02, 2009
-   won't display a picture it show a white screen
-   cat52
Feb 25, 2009
-   My Nokia N76 goes blank when turned on.when i open the flip the screen goes blank or sometimes blinks rapidly on n off.
Please help-   Guest
Feb 08, 2009
-   DEN ENERGOPOIATE KATHOLOU TO THLEFWNO M KAI ANOIGEI MONO OTAN EINAI STON FORTISTI GT OMWS?
-   Guest
Nov 02, 2008
-   when on the phone its just show nokia white screen cant turn it off.-   miey_ridz80
Apr 11, 2008
-   i was typing a text message when all of a sudden a weird line comes on the screen. so i tried to turn power off my sk3 but it didn't. so i took off the battery and turn it back on after replacing the battery but it didn't work. i tried charging it and then turning it on but no solution.-   pedrog3
Best Solution
posted on Mar 10, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I found a post where one fellow said replacing the battery worked...
http://www.expansys-usa.com/ft.aspx?k=59275
Solution #2
posted on Feb 08, 2008
Somewhat Helpful)
maher0507
Rank: Wiz
Rating: 81%, 81 votes
it could be software or u need new screen
but it could be also liquid damage
Was this helpful?
Yes
No
Solution #3
posted on Jan 12, 2009
Not Rated)
cmbcleveland
Rank: Apprentice
Rating: 100%, 2 votes
This sounds like a common fault of a faulty ribbon cable which connects the screen to the main PCB. Normally goes faulty on a flip or slide phone due to constant movement. Can be replaced fairly cheaply. contact cmbcleveland@ntlword.com for prices
Was this helpful?
Yes
No
Solution #4
posted on Nov 02, 2008
Not Rated)
miey_ridz80
Rank: Apprentice
Rating: 0%, 0 votes
when switched on the phone,my phone screen only show nokia and i want to turn off cant. how to solve this problem?
Was this helpful?
Yes
No
Solution #5
posted on Sep 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my phone does the exact same thing...
Solution #6
posted on Mar 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My phone has done the same thing. You have to get a new one :(
Popular Solutions for Nokia N76 Cellular Phone
Questions and Unsolved Problems for Nokia N76 Cellular Phone
Do you recommend Nokia N76 Cellular Phone?
Answer
Answer
it displays "unable to perform bluetooth operation"
Answer
I cannot access the web on my N76,How can I access it again?I use to access it but after several... (More)
Answer
press call+*+3 this trick not working any other trick n76 Phone start-up failed. contact the... (More)
Answer
After a little digging around on the net, I managed to get back into the handset by doing pressing... (More)
11 Other Users Have The Same Problem - Continued
Comment by Conniea, posted on Mar 25, 2008
I've removed the battery 5 times, this has happened a few times in the past few months but usually removing the battery does the trick.
Comment by cjgj, posted on Mar 05, 2008
6133 white screen
Comment by Guest, posted on Mar 04, 2008
when I opened my phone is it ok and I can call and send from it anything but the problem is I cant see anything ( the screen is black )
Comment by susieq246, posted on Feb 19, 2008
both my main screne and sub screne has gone blank.
Comment by Dougaldow, posted on Feb 13, 2008
my screen turns white and brings up the nokia sign but then it just goes blank for a second and turns completely white again.
Comment by Geo4k, posted on Feb 13, 2008
Daughter's Katana has a "white screen of death". Small LCD on the front works, but phone is inop.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phones Experts
Top Cell Phone Repairmen
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
