Question about Radio Shack Pro-96 Scanner
Scanner not working
Cannot open Banks 4, 5, 6, 7, 8 and 9. Will not take any new programs.
The antenna connector is loose!?
Go to Don Starr software link at:
http://starrsoft.com/software/win96/default.asp
The best $30 you will spend to make the Pro 96 sing for you.
Also use:
http://www.radioreference.com/
This site has all you need to get going and a direct download of frequencies and talk groups for trunked systems...
Cheers,,,Tom M sends
Posted on Mar 26, 2008
Did you use a software program or have radio shack program the scanner for you? If so, check to make sure the banks were selected in the software to be enabled. I assume the your scanner shows 0123****** Now to manually select banks, simply press the number for the selected bank to both select and de-select as warrented. When you press 4, bank 4 will now be scanned. Also, should you press 1, bank 1 will not be scanned.
Posted on Feb 13, 2008
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
I have tried to adjust my squelch but all i hear is loud static in between transmissions
  • Hi, I can help.
  • If your getting transmissions then the receive is working.If your squelch is not adjusting out then it is possible your antenna, or the connector, is not working right. Hand held scanner antennas are the same across the board as for frequency use. The connector your antenna uses is a standard BNC connector. So your antenna is really universal which mean you don't have to go to Uniden and pay top dollar for their antenna.
  • Now it is possible the squelch knob is giving you trouble. but I would see if you can borrow an antenna just to try from anyone you know that has a hand held scanner. As long as their scanner works well with that antenna it should on yours too. If it don't then check the connector for the antenna on the scanner and make sure it is not loose. You can open the scanner and just eyeball the connections and make sure no soldier joints are not cold.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 17, 2011 | Uniden BC72XLT Handheld Scanner
Scanner antenna causing static
Sounds like a bad, loose or dirty connection.
it's possible that there may be a broken soldered joint on the antenna connector.
Open up( power off first) and resolder the joints as they can breakdown over time(dry joint).
Aug 14, 2009 | Electronics - Others
Antennas Uniden Bearcat BC148XLT
Height and placement of the antenna determines range. Also, check to see you have the antenna perpendicular to the ground (straight up), and place the antenna where it has 19" clear around it. (not up against a wall or other obstruction)
Placing the existing antenna higher, or replacing it with an external antenna would give you more range. A simple test before purchasing a new connector, coax and antenna for the scanner, would be to place the scanner where you think you would place an antenna and see if it gives you the range you desire.
External antennas are available from most any radio shop. (They would need to know what type of connector you need to connect the coax to the back of the unit.)
Sep 09, 2008 | Radio Communications
Just bought this scanner used and having problems with Banks 3 and 4
while the scanner is scanning press buttons 3 and 4 and they should start scanning too, if they dont then go to the first channel in bank 3 manually and press LO to unlock it, then hit manual again to go to the next channel and press LO again to unlock it( all of the channels in the bank are probably either locked out or empty(nothing programmed into them)
Sep 05, 2008 | Uniden BC80XLT Handheld Scanner
Bank are locked out
Simple, some Radio Shack models respond to their preset lock out override control protocol. Try holding the lock out button and the scanner should override the lock out on the banks. If that doesn't work, you may need to un-lock them one by one, which may be time consuming. Or, you could reprogram the scanner all together.
Hope this helps!
Jun 30, 2008 | Radio Shack Pro-2096 Base Scanner
My scanner
You may have lost your antenna connection.. Is the connection point loose (rotates a little) if you remove the antenna?
If yes, they you need to open it up and repair the connection, and re-tighten the BNC connector..
Jun 21, 2008 | Uniden BC60XLT Handheld Scanner
Trunking frequencies
Did you initialize your scanner? If you did, then you also deleted your trunking banks (1-9). These are the banks that store the channels that were inputted by you. The scanner will display "All channels locked out," when all of these banks are empty. You may have to put the frequencies in again. I suggest using win97. There is a 30day trial. This is the only program that I know of that will work with this scanner.
The pre-programmed channels should still be there. If you press and hold the scan button for a couple of seconds you should see the signal stalker running.
Good luck.
May 02, 2008 | Radio Shack Pro-97 Handheld Scanner
Cant get anything
Sounds to me like the antenna connector is damaged or loose, or the scanners receiver is faulty. If the antenna connector is loose, you could try to reinforce it by soldering the separated wires or ports. If the receiver is faulty, you'll have to get a new scanner.
Hope this helps!
Apr 16, 2008 | Uniden BC72XLT Handheld Scanner
Radio Shack Pro-96 Scanner Logo
134 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
